GM had BETTER NOT...
Old Sep 30, 2009 | 04:58 PM
  #76
Prorac1's Avatar
Thats the problem with catagorizing people or cars. Everyone on here knows the differance between a car guy that now has the money for better things, and the guy that now has money and goes out and buys a fast car and "thinks" hes a car guy. Eric L
Old Sep 30, 2009 | 05:19 PM
  #77
jg95z28's Avatar
No they offer a modification package for the CTS-V. This has nothing to do with the Camaro.
http://www.hennesseyperformance.com/...ctionReq=Where
Yeah, I realized after I posted that you may have been talking about the CTS-V not the Camaro.
Old Sep 30, 2009 | 06:32 PM
  #78
wildpaws's Avatar
Originally Posted by PacerX
However, from my understanding, CTS-V LSA's are already grenading their bottom ends because of weak components.
Rather than your "understanding", how about providing some documentation such as links to articles, threads on CTS-V forums documenting issues, or something similar.
Clyde
Old Sep 30, 2009 | 06:51 PM
  #79
Zigroid's Avatar
why are supercharged LS1s surviving with 500 rwhp and an LSA is at its limit at 556 flywheel hp?
Old Sep 30, 2009 | 07:05 PM
  #80
SSbaby's Avatar
Originally Posted by jg95z28
I disagree about the LS7 being more economical. Cost-wise its a wash, until you include the LS7's dry sump oil system. Furthermore, being a bigger engine that's fairly close to the limits of the bore-size the LS block can handle, there's a bigger potential for parts breakage. No doubt, I'd rather see a detuned LS9 than the LSA because of the forged internals, however the LS7 would need more internal mods to increase performance, whereas the LSA and LS9 would merely need a pulley swap. (See below.)
Err, excuse me but the LS9 also contains a dry sump system.
Besides, blown engines always cost more to build and maintain than NA engines. That's fact.
Old Sep 30, 2009 | 07:07 PM
  #81
SSbaby's Avatar
Clyde
You don't need to question, PacerX. He know's exactly what he's talking about... more than most here.
Besides, cast pistons aren't great for blown applications. It's common knowledge. It's like a hand grenade waiting for somebody to pull the pin...
Old Sep 30, 2009 | 07:11 PM
  #82
jg95z28's Avatar
Go back a few pages where I said "I'd rather see a detuned LS9 (minus the dry-sump system)."
Old Sep 30, 2009 | 07:12 PM
  #83
SSbaby's Avatar
Originally Posted by Z28Wilson
Maybe, maybe not. I have yet to see you or SSbaby give any credible reason why GM should NOT reinforce their performance reputation by forging the internals of the LSA. Cost? We're talking about the Corvette-money Camaro here, not the base LS.
Hey, leave me out of this debate, I'm all for forged pistons in hi-po LSx. All I said was the Cadillac owners would be less likely to want to drag race their cars... unlike the Z/28 owners.
A blown GM V8 NEEDS forged steel pistons. PacerX knows what he is talking about.
Old Sep 30, 2009 | 07:13 PM
  #84
SSbaby's Avatar
Well the same could be had for the LS7 if that were your logic.
Besides, HSV have already developed a dry sump system for the HSV W427... you know that right? So some of the development would be carried over to the Z/28 I would imagine.
Old Sep 30, 2009 | 07:16 PM
  #85
jg95z28's Avatar
Fact?
Actually I'd say "modified" engines cost more to maintain, blown, NA or turboed. Factory engines cost less to maintain than "modified" engines, blown, NA or turboed. Our 96 Mustang with a Vortec S/C was a money pit. However, I'd never compare it to a factory supercharged Mustang.
Just because Joe Blow bolts a supercharger on his stock engine doesn't mean it can handle the boost. However a factory supercharged engine that is engineered and designed to handle the boost is a different animal altogther.
Old Sep 30, 2009 | 07:19 PM
  #86
jg95z28's Avatar
You've also missed my (and others') comments that a LSA or LS9 can see improved performance with a simple/cheap pulley swap; vs. the LS7 which needs more $ and development/time for similar improvements.
Old Sep 30, 2009 | 07:32 PM
  #87
SSbaby's Avatar
Fact?
How do you figure? The LS7 is cheaper to make than either the LSA/LS9... by over a few grand. That's money that could be saved by the consumer.
A cam upgrade on the LS7 would be not much different cost-wise than your average cam upgrade for the LS3. Uber power without the top heavy blower in a tight package... should be enough power for most. LS9 would almost be overkill... but having said that, Ford seems to be committed to the 5.0L EB...
Really, I'm not fussed whether GM decides to slot an LS7 or LS9 as I won't be an influential target person for that type of car. I'm just offering my 2c, FWIW.
Old Sep 30, 2009 | 08:23 PM
  #88
wildpaws's Avatar
Knowing what you are talking about and documentation are two ENTIRELY different things. I personally like to see facts and documentation rather than "understanding". I frankly have not heard any info about CTS-V LSAs "grenading" themselves, nor have I seen it mentioned on any other forums, that's why I wanted a source for this info.
Clyde
Old Sep 30, 2009 | 08:29 PM
  #89
SSbaby's Avatar
Clyde
Understand where you are coming from. As a learning guide... http://www.carcraft.com/techarticles...ogy/index.html
If you want examples of blown-up LSA engines, I dunno, but I'm sure there are many tech forums of racers sharing their personal experiences...
Old Sep 30, 2009 | 09:48 PM
  #90
Z28Wilson's Avatar
An interesting back-and-forth about cast LSA pistons can be found here:
http://www.cadillacforums.com/forums...p-846tq-3.html
Originally Posted by Prof
IMO if you are going to go much beyond 10 lbs of boost, it is fool hearty to not forge the rods and pistons in an LSA...but I have never stayed in a Holiday Inn Express...
The OP is apparently running 821 HP (on nitrous) through his stock bottom end...will be very interesting to see how long that lasts, as others seem to be a bit skeptical as well....
