1994 camaro 3.4l fuel pump shuts down
Old 05-08-2012, 08:21 PM
Dcamerada's Avatar
I just recently Changed the fuel filter in my car but the car still has the problem of starting then cutting out within 5-10 seconds. I checked the relay and it seems to be working fine and the fuel pump seems to work then it simply cuts off...what do I do.? Or what should my next step be?
Dcamerada is offline
Old 05-08-2012, 09:59 PM
Re: 1994 camaro 3.4l fuel pump shuts down
This is the "LT1 Based Engine Tech" forum. It's for the 5.7L LT1 V8 engine related topics. Since you have the 3.4L V6, let's move your post to the "V6 Tech" forum, where people are better equipped to address your specific problems.
Injuneer is offline
Old 05-11-2012, 11:23 AM
Mevissen's Avatar
Mass air flow sensor might need to be cleaned or replaced. That's what my problem was
Mevissen is offline
Old 08-18-2012, 02:21 AM
94Camaro's Avatar
In terms of cleaning the MAF sensor, the 3.4L is a speed density engine:
Speed density cars use a programmed set of variables to deliver the fuel requirements of the car. It reads things like engnine temp, throttle position, 02 sensor, etc and delivers a set fuel curve. However, it cannot determine what mods have been done to the engine. Install a cam, which allows more air to enter the engine, and the computer cannot compensate. This usually leads to problems.
What this means is that the MAF doesn't exist on a 3.4L V6 - the computer wouldn't know what to do with it if it was installed anyway.
What you need to do (this is a must for anyone trying to troubleshoot any 1993 or later vehicle) is get your car scanned somewhere or buy a scanner and do it yourself. The reason for this is twofold:
1) The scan will give you codes that will help you track down the issue.
2) The 3.4L has a speed governor. If you hit 108mph, the pcm will limit the fuel relay and could lead to engine shut off (I've experienced this in my car). It's entirely possible you have a E/PCM problem and the code scan would reveal this.
You really need to have the E/PCM scanned to see if any error codes have been thrown before trying to go any further on this problem.
94Camaro is offline
Scottylt1
01-08-2015 02:48 PM
ANDYZ28
12-29-2014 09:13 PM
Scottylt1
12-04-2014 12:31 PM
blac94Z
11-24-2014 07:12 PM
Zomie
07-25-2002 07:52 AM
Quick Reply: 1994 camaro 3.4l fuel pump shuts down
