96 brake issues
Old 08-15-2016, 03:35 AM
gingy1987@hotma's Avatar
96 brake issues
Have a 96 z28 have changed front brakes rotors calipers master cylinder. Rear brakes and on caliper. When I got car brakes were squealing. Now I have changes front brakes and rotors again due to dragging. Now my abs unit light is on. Need help with what is wrong why my brakes continue to drag. I'm burning pads and rotors up front and the rear seem to drag as well. Please help thanks
gingy1987@hotma is offline
Old 08-15-2016, 04:21 PM
cheapchevy's Avatar
Re: 96 brake issues
Did you scan for DTCs?
Your Electronic Brake Traction Control Module (EBTCM) stores Diagnostic Trouble Codes (DTCs) that can be read with a scan tool connected to your Data Link Connector (DLC) under your dash. My service manual says you need a Tech 1 scan tool, not sure if other will work.
If you can provide DTCs, we can look up the codes from the factory service manual.
cheapchevy is offline
Old 08-16-2016, 04:47 PM
Re: 96 brake issues
Surprisingly, Scan9495 will read the 1996 ABS codes.
https://www.camaroz28.com/forums/com...3/#post6948005
https://www.camaroz28.com/forums/com...95-lt1-874306/
You can also download a free copy of the 1996 factory service manual here:
LINK: 4TH GEN SERVICE MANUALS - Firebird Nation
Injuneer is offline
96SilverRam
11-20-2016 11:19 AM
REDNECKISBOSS
05-20-2015 10:03 PM
pologreen97z
05-18-2015 02:17 PM
camaro98_speed
04-22-2015 11:26 AM
Charged
09-25-2002 09:28 AM
Quick Reply: 96 brake issues
