ignition set up
Old Jan 22, 2003 | 09:48 PM
dnz28's Avatar
ignition set up
I have a jacobs milage master and I want to run a 150 shot will that give pre detnation
Old Jan 23, 2003 | 01:23 PM
COMNBYU's Avatar
nitous will work fine with your stock ign. up to a certain point. anything aftermarket will only help the situation. as long as youve got a good spark, you should be fine.
most people running N2O are more worried about detonation because of not having enough fuel and leaning out. there again, the factory pump will work fine up to a point, but any aftermarket parts will only help.
i wouldnt any higher than 150 with factory parts.(ign., fuel system, etc)
jon
Old Jan 23, 2003 | 03:29 PM
dnz28's Avatar
thanks
Old Jan 24, 2003 | 11:52 AM
chesee48's Avatar
digital 6
Dec 1, 2016 05:37 PM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
Mar 15, 2015 07:01 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
