in-line fuel booster ?
Old Mar 24, 2009 | 09:43 AM
camit282's Avatar
Remove inline fuel booster?
I am replacing my in tank fuel pump with a wa. Hp Fuel pump, I put a inline fuel pump so i woild not have to replace the one in the tank.. Dumb move i made 2 years ago when i built the motor, because now it is showing signs of the in tank pump dieing.
My question is do i leave inline fuel booster in it is zex inline booster http://store.newlevelmotorsports.com/zexinfuelpum.html Or do i take it out and put a line in the place with comp. fittings? Can i kill the power to the pump and will the fuel still flow threw there, or do you have to have the pump running to boost the fuel?
Old Mar 24, 2009 | 07:54 PM
Remove the inline booster pump. It will restrict flow if its not powered. And if you are getting the high pressure Walbro, you all covered on high flow/high pressure applications.
Old Mar 24, 2009 | 08:22 PM
camit282's Avatar
Okay I will do that, guess ill sell the thing Do you think my best bet is to install a new steel line with a comp. fitting? I have the booster right after the fuel filter so ill just have to replace that some section of line. Thanks for help
Rod Bender
Nov 7, 2023 02:30 PM
Rod Bender
May 16, 2015 02:16 PM
ad356
Apr 16, 2015 05:38 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
