Fuel pump bucket
Old Mar 11, 2009 | 06:13 AM
BA383TA's Avatar
Fuel pump bucket
What have you guys been using to secure the top of the fuel pump bucket when you install a new pump? Bill
Old Mar 11, 2009 | 11:58 AM
94SLUG's Avatar
Race Tronics sells a special glue (probably NAPA too), the first time I used some clamps...
Old Mar 11, 2009 | 12:03 PM
Kevin Blown 95 TA's Avatar
That glue didn't hold on mine. When I took it out again to do dual pumps, it was all apart. I researched it and there is some aviation glue that works in fuel - not sure if that was in the little packets Racetronix provided or if it was some more common epoxy - whatever it was, it didnt work.
Old Mar 12, 2009 | 12:59 AM
dr97z's Avatar
Not saying you didn't do it, but the stuff they send is suppose to set up over night, which is commonly missed especially if installed by a shop which isn't willing to wait over night. Just my experience.
Old Mar 12, 2009 | 01:33 AM
MikeGyver's Avatar
I scraped all the residue off with a razor blade and brushed on a schload of superglue. Superglue isn't a filler type glue, so if you can get both pieces to a nice, clean, gapless fit, it'll work well.
I've had the pump out 3 times and it's holding up fine so far.
Old Mar 12, 2009 | 04:34 AM
za355tx's Avatar
Thanks for the replies. Now I have some options. Bill
Old Mar 12, 2009 | 05:16 AM
Wrong forum..... moving to "Fuel and Ignition".
Old Mar 13, 2009 | 04:34 PM
mzgp5x's Avatar
Seal All. Available @ most auto hardware stores. Commonly used to seal gas tank leaks. B.
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
