Need info on headers
Old Feb 13, 2009 | 03:09 PM
cboggs5's Avatar
I WAS THINKING OF BUYING SOME PACESETTER HEADERS AND WAS WONDERING IF THEY WERE A GOOD BRAND THIS IS THE INFO ON THEM
Manufactured using mandrel-bent, mild steel tubing and surface-ground, thick steel flanges, PaceSetter Headers are available with standard black painted finish or Armor*Coat, a polished, 2000 Degree F, metallic-ceramic coating. Each header undergoes an extensive preparation phase followed by two applications of the coating and a high-temp curing process. The Armor*Coat won't discolor like paint, chrome or dull finish coating, reduces underhood temperatures, resists rust and corrosion and is easy to keep clean. All PaceSetter Headers come with hardware, gaskets and illustrated instructions and are backed by a three-year warranty. Header bolts not included.
Quality Manufactured in the USA and affordably priced
CNC-machined 3/8" think steel flanges are matched to exhaust port profile for optimum seal and flow.
Flash-controlled 16-gauge carbon steel primaries provide greater durability than light gauge stainless steel.
Length and diameter of mandrel-bent tubing is optimized for flow and best performance increase.
One-piece design installs easier
Complete with necessary gaskets and fasteners for installation
Header Type: Full-length
Tubing Diameter: 1-3/4"
Collector Diameter: 3"
Old Feb 13, 2009 | 03:16 PM
mr.green's Avatar
Yes, are very good headers for the price. although there are better ones out there these should do you just fine.
Old Feb 13, 2009 | 03:27 PM
cboggs5's Avatar
so should i get the y pipe or can i use the stock one
Old Feb 13, 2009 | 07:33 PM
camarobird92's Avatar
You need the new Y-pipe.
Old Feb 14, 2009 | 02:33 PM
Hard to understand how you expect anyone to answer your question, when you have provided ZERO info on your car.
I'll make this suggestion one more time.... and then I'll stop bugging you (and trying to help you).
ADD A SIGNATURE
Old Feb 14, 2009 | 04:19 PM
mrmint69's Avatar
You get what you pay for. They are a good deal for the price. I recommend the coated headers.
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
alex5366
Exhaust System
Feb 24, 2015 09:12 AM
bernie1951
Dec 10, 2014 10:03 AM
SpeedJunkee
Dec 9, 2014 10:17 PM
