is this an opti problem?
Old Aug 27, 2008 | 01:13 PM
23tigga's Avatar
Question is this an opti problem?
My car will just turn over but won't crank I checked to see if fuel was coming up through the lines and it was so I guessing that its not igniting i guess but could someone help me out because I planning on going through with the opti surgery in the morning
Old Aug 31, 2008 | 08:42 PM
stvski80085's Avatar
Check for spark
Look for spark so you know thats good. What about your fuel filter?
Old Aug 31, 2008 | 08:44 PM
re
Just pull one plug and turn the motor over. You should get a spark if you holfd it near ground on the bolck or headers.
Old Sep 3, 2008 | 06:07 PM
23tigga's Avatar
Sorry for the update been tied up but put the new opti on and still no results just turns over I can hear the fuel pump priming and just don't have no clue as to what it could be
Old Sep 4, 2008 | 07:51 PM
brahm's Avatar
It could be ICM/COIL, Opti just passes the spark alone.. unplug your wire from the opti/coil, and replace it with a spark plug wire put a plug on the end, and ground it (lean it) against your block. Crank it and look for spark. If you have no spark out of the coil, then I'd look at replacing the coil or ICM (and or checking all the wires leading to them)
Old Sep 4, 2008 | 08:24 PM
Have you scanned it for codes?
Old Sep 7, 2008 | 04:22 PM
IPrice's Avatar
How about going through some of Shoebox's "how to's?"
http://shbox.com/1/4th_gen_tech2.html#opti_test
Might be able to help diagnose before you keep throwing money at it.
-Ivan
greenzee28
Mar 26, 2015 09:13 AM
grabbem88
Mar 18, 2015 01:25 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Injuneer
Dec 15, 2014 09:36 AM
