Replacing opti-spark with LS-1 Ignition
Old Jan 14, 2008 | 04:37 PM
ledfut1's Avatar
Cool Replacing opti-spark with LS-1 Ignition
I was checking out a Z-28 on e-bay. He mentioned changing opti-spark in a `95 LT-1 with ignition from a newer LS-1 system. How big of a job is this.. My `95 is tore down now and would be a good time to change if not too technical of a job..Anyone have any info. on this changeover? thanks
Old Jan 14, 2008 | 05:18 PM
Perhaps he's referring to the LTCC setup from Bailey Engineering:
http://www.bailey-eng.com/LTCC.html
The only LS1 coil conversions I have seen, like the LTCC or my own MoTeC setup still use the Opti optical signal as the cam position sensor. The stock LT1 PCM needs the optical signals from the Opti to time the fuel and spark. It will not function without at least the low resolution pulse pattern from the Opti.
Old Jan 14, 2008 | 07:43 PM
IROCThisZ28ForLife's Avatar
go to search and type in delteq or ltcc as Injuneer pointed out, plenty of info there boss
Old Jan 15, 2008 | 07:30 AM
ledfut1's Avatar
okay.. thanks
Oncomingstorm22
Jan 22, 2015 07:15 PM
ScottZ
Mar 3, 2004 01:34 PM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
Caps94ZODG
9
Jul 26, 2002 03:36 PM
