And... I need a torque arm
Old Dec 24, 2007 | 02:50 AM
tom3's Avatar
following my original post: https://www.camaroz28.com/forums/sho...d.php?t=562976
It turns out that my torque arm is broken. The metal has a one inch rip on the bottom, by the differential.
I have now a few questions:
- Stock vs. Aftermarket? Is there a big difference?
- I have LT headers, do aftermarket have the same clearance?
- The shop I asked quoted 3 hours of labor to change the torque arm, that seems quite excessive to me.
Old Dec 24, 2007 | 10:34 AM
rskrause's Avatar
Well, an aftermarket TA probably wouldn't have broken! They are much stronger. And yes, three hours seems like a lot. It is an easy DIY job, just be careful to keep the diff from rotating once you remove the TA.
Rich
Old Dec 24, 2007 | 11:32 AM
93v8clone's Avatar
spohn sells a nice chassis mnt setup meant for long tubes and regular.....plus one for not lettin rearend rotate when ya do it its a beotch to get it centered again
Old Dec 24, 2007 | 12:40 PM
Shon Herron's Avatar
25th and 26th UMI is running a sale that I am participating in, please look here:
https://www.camaroz28.com/forums/sho...d.php?t=565738
1) There is alot of difference between stock and aftermarket, you will not be dissappointed.
2) LTs are no issue
3) no comment on other shops procedures.
Old Dec 24, 2007 | 03:25 PM
tom3's Avatar
so, now I have options:
- Jegs
- Edelbrock
- Spohn
- BMR
other option here (talk about ladder bars):
http://ls1tech.com/forums/archive/in.../t-562337.html
the question remains how street friendly is this...
I am totally clueless about suspension, so I am doing some google-reading, but I would appreciate any advice/experience from you guys
Old Dec 24, 2007 | 03:42 PM
Add UMI, madman, etc, alot of places make a TA, and if you look at the design they are nearly all the same, each one have a different little something but in the end they are all pretty much the same. Normally comes down to price and options, ie drive shaft loop (recommended!)
In my opinion I would get one that mounts to a crossmember rather than on the Trans, this gets the stress off the tailshaft. and get an adjustable one so you can set the pinion angle.
I can quote you a TA for your needs from Spohn or UMI if you want.
- Jegs
- Edelbrock
- Spohn
- BMR
Old Dec 24, 2007 | 09:44 PM
rskrause's Avatar
The Spohn is a very nice piece. Agree about getting the mount off of the tranny.
Rich
Old Dec 24, 2007 | 09:49 PM
mdacton's Avatar
Rich
+1 for spohn......several cars I know and worked on myself all went with spohn, high quality and never had a problem with anything
Old Dec 24, 2007 | 09:57 PM
Agree, I run the spohn on several cars, UMI sales a butt load!
Old Dec 25, 2007 | 04:35 PM
nicks2ndZ's Avatar
i run a spohn from Herron Performance and I am more than happy with it.....+1 for DS safety loop and adjustable
Old Dec 25, 2007 | 04:53 PM
mdacton's Avatar
Shon Herron is a good guy to deal with too, went out of his way to help me out with something
Old Dec 25, 2007 | 09:15 PM
Z-RATED94's Avatar
Spohn chassis mounted here, nice piece.
Old Dec 26, 2007 | 10:51 PM
96' Formula WS6's Avatar
Quick question. Dont you only have to adjust your pinion angle if you are lowering the car.
Old Dec 27, 2007 | 08:37 AM
Z-RATED94's Avatar
What about old springs that aren't the same height anymore? I guess you could just check with an angle finder. What makes the chassis mounted aftermarket adj. TA so nice is, you get the stress off the tranny, you would have to have an ungodly amount of HP to even try to break one. They help the car launch better, and any time you take weight out or move it (as in battery relocation) you climb under the car and adj. the pinion angle.
Stephen68
Parts Wanted
Sep 27, 2015 06:42 PM
autoxr166
Sep 25, 2015 04:21 PM
Jake Bialke
Sep 24, 2015 11:31 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Bxlt1
Sep 17, 2015 08:31 AM
