Code P0001 and P0003- Is this a bad fuel pump?
Old Nov 23, 2007 | 08:07 AM
Matts97camaro's Avatar
My car just died going down the road. I scanned the OBDII I got these codes. It will not start for anything, just turns over. I think its the fuel pump. What do you all think? Car is a 1997 Camaro V6. Broke down driving to my inlaws house on Thanksgiving day, what a day.
These are the DTC generic definitions that my scanner pulled from the OBDII
P0001- Fuel volume control circuit open
P0003- Fuel volume regulator control circuit low
Old Nov 23, 2007 | 10:28 AM
Wrong forum... "LT1/LT4 Engine Tech" is for the 93-97 V8 engine. I'll move your post to the V6 forum. You also might want to check your codes.... none of my sources list anything under P0101 for the V6 engines.
Old Nov 23, 2007 | 08:38 PM
All
I found the problem. I don't know why I got a fuel code. It was a blown fuse for the ignition. I replaced the fuse and the car ran for about 5 min then blew the fuse again. I scanned the computer and found a P0300 code- misfire. I found the ICM to be bad. I took it to the parts store to test, it was bad along with 1 coil. I replaced the ICM and coil and fuse for 160. Installed everything myself and she is running great. Glad it was not the fuel pump...
Scottyboy
Feb 11, 2015 10:28 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
Gtpguy
Jan 26, 2015 04:50 PM
ANDYZ28
Dec 29, 2014 09:13 PM
blac94Z
Nov 24, 2014 07:12 PM
