How to stop leaking headers at flange?
Old Oct 1, 2007 | 10:42 PM
mrmint69's Avatar
I installed Pacesetter mids. The Y pipe to the headers was not a snug fit on the passenger side. I had to put the bolts on and torque them down to get it to seal. It looks pretty good but a have a ticking sound coming from that exact area. What i would like to know is there a simple way to seal it without having to go through much trouble? Its in no mans land as far as access so is there any snake oil or home made trick that will help? I used aluminum foil on the slip joints and it worked great but this it a flange.
Old Oct 2, 2007 | 07:54 PM
wildweasel's Avatar
Metal gasket, sealer on both sides. No simple solution that I can think of.
Old Oct 3, 2007 | 05:59 PM
The Percy's dead-soft aluminum collector gaskets may help. Did you check the collector flanges to make sure they were flat? Or is sounds like you may have bent the flange by using the bolts to pull the poorly fitting connection together.
Old Oct 3, 2007 | 08:51 PM
mrmint69's Avatar
Percy's 66001 2-1/2'' Collector Gaskets JEGS. Made of a special ''dead soft'' aluminum, they conform to collector flanges allowing for an ultimate seal.
Well here is the auction on Ebay for only $26 shipped. Would be worth every penny if they fix my leak. They weren't that bad in lining up and the headers where they connect are very think and appear to be solid. I will give it a shot. Thanks, Fred
Old Oct 6, 2007 | 08:36 AM
Z-RATED94's Avatar
Glad to hear the aluminum foil trick worked for you.
Old Oct 8, 2007 | 04:31 AM
NemesisLT1's Avatar
I second the percy's gaskets, they sealed mine and im missing a bolt....
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
BigWil
Mar 29, 2015 12:24 PM
alex5366
Feb 17, 2015 10:43 PM
Scottylt1
Jan 8, 2015 02:48 PM
Scottylt1
Dec 4, 2014 12:31 PM
