S Term Counts
Old Jul 26, 2007 | 07:45 AM
93BlackTA's Avatar
S Term Counts
What would cause the short term counts to be extremely low like 1 or 4.....its 128 at idle...also my Long term counts are 128 at idle, and mostly 108-128 after
Can someone give me some idea's
Old Jul 26, 2007 | 05:45 PM
If the short terms are 128 at idle, when do the drop to 1 to 4?
The only reason they would go that low would be if the long terms had bottomed out at 108, and the engine was still running rich (at least according to the O2 sensor voltage). Then it starts lowering the short terms to lean it out further.
Old Jul 26, 2007 | 06:38 PM
93BlackTA's Avatar
After the car goes into closed loop the long terms are mostly 108...then the short terms are very low. ive seen L&R long terms at 108 and 113 and the L short term at 1 and the R short term at 148
Old Jul 26, 2007 | 10:54 PM
The short terms should be swinging back and forth, both above and below 128. If they are always down low, they are trying to correct a rich condition that goes beyond the capabilities of the long terms. But you can't just pick one value out..... that's why you do a data log, so you can look at changes and values over a longer period, look at average values, etc.
Old Jul 27, 2007 | 05:00 AM
93BlackTA's Avatar
ok, i had a very reputable person look at my datalog and he informed me that i'm extremely rich overall but runnning lean at higher RPM and WOT. What can i look for to solve this rich problem.
Old Jul 27, 2007 | 11:59 AM
MEAN LT1's Avatar
Sounds like you need to get that bad boy tuned.
Old Jul 27, 2007 | 01:24 PM
93BlackTA's Avatar
I wish i had a good dyno close by...the closest one that does efi cars is aprox 1000-1200 miles away.
NewsBot
Sep 30, 2015 04:20 PM
NewsBot
Sep 15, 2015 11:53 AM
NewsBot
Sep 14, 2015 02:02 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
gonzo275rltw
Sep 5, 2015 06:26 PM
