Put the car on the dyno yesterday
Old Jun 21, 2007 | 07:13 AM
AL SS590 M6's Avatar
because of a no shift problem. Thought we had it resolved but that's another story that can be found in the drivetrain forum.
Made a power pull to check the afr after the Darts and the 90/90.
It made 397.5 hp and 331.4 tq on a Mustang dyno with the torque converter unlocked.
At the track last night on the one clean pass that I made it ran 11.12 @ 120.73 with a DA of around 2800'. Not to shabby when you look at the number in my sig and it was at a DA of 700'
Old Jun 21, 2007 | 08:58 AM
SSpdDmon's Avatar
Nice...Sean's a good guy. Got me to re-think the way I tune.
Old Jun 21, 2007 | 07:01 PM
Originally Posted by robvas
What cam are you using?
APE custom grind. 228-236 .600+ lift with the 1.75 rockers 114 ground 2 degrees advanced.
Old Jun 21, 2007 | 10:22 PM
Kraest's Avatar
Retired
Good numbers for an auto. Which Darts? Hopefully the 225s
The 205s were only around +15 rwhp over my buddies stock LS6 heads when he put them on his 6-speed Z06.
Old Jun 22, 2007 | 08:33 AM
Yeah auto, unlocked converter and Mustang dyno.
Dart Pro 1 225s, Fast 90, PRC 90 were the changes for this year.
And for those that might get a PRC 90mm throttle body. Do yourself a favor and open up the IAC hole before you install it. My car wouldn't idle after the swap so I took it to my tuner thinking that it was in the tune. He took the tb off and opened up the openings a little, put it back on and it started up and idled with no tuning needed.
mr28
Apr 20, 2016 05:44 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
ModdedNerd
Dec 18, 2014 10:52 PM
USAirman93
Nov 24, 2014 03:37 PM
Klypto
Jul 24, 2002 11:21 AM
