Which Of These Coils Would Be The Better '94 Replacement?
Old Apr 9, 2007 | 05:28 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
Crane
MSD
I have to say that the Crane is winning in the d a m n sexy department, but the MSD has some pretty big numbers, of which I'm completely unfamiliar.
Are there other alternatives I should be considering?
I guess the link wasn't working. Sorry. I've inserted links for the coils I'm talking about.
Old Apr 9, 2007 | 05:48 PM
2000GTP's Avatar
Your not going to see power gains with them. A stock Delco replacement would do the trick nicely as well.
Old Apr 9, 2007 | 06:15 PM
BTC's Avatar
BTC
I've heard that the coils on the early LT1's left a little to be desired as far as output. I think GM changed the design in 1996 or 1997, but I'm not familiar with the specifics. That's the only reason I'm considering changing mine out when I replace the distributor. I also thought a stronger spark and longer duration might help if the car had been running rich, which I believe has been the case considering I've had trouble in the past with catalytic converters.
Klypto
Mar 23, 2016 09:05 AM
grabbem88
Mar 18, 2015 01:25 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Alex Barnes
Jan 24, 2015 10:21 PM
