Fuel Filter
Old Mar 19, 2007 | 09:26 PM
MasterZ28's Avatar
Fuel Filter
Do i really need a fuel pressure gauge to relieve gas pressure in the fuel lines in order to install a new filter??? I just want to put it in already without having to wait to buy this damn thing.
Old Mar 19, 2007 | 09:35 PM
mrmint69's Avatar
I removed the gas cap to relieve the tank pressure and then let the car sit for a couple hours and i had only minor spills. A gauge is only useful if the line is under pressure and since the system drains after time you have very little if any.
Old Mar 19, 2007 | 10:30 PM
shoebox's Avatar
Who said you needed one? http://shbox.com/1/fuel_filter.html
Old Mar 20, 2007 | 09:08 AM
2000GTP's Avatar
You would use the fuel pressure gauge more or less to test the integrity of the fuel system, not to do a maintenance repair of a fuel filter swap. I just uncapped the gas cap to relieve the pressure. Otherwise, when you break the lines to get the fuel filter off, you will be taking a bath in gas.
Old Mar 20, 2007 | 04:08 PM
shoebox's Avatar
Removing only the gas cap only, does not relieve pressure in the lines. If it has been sitting for a while there may be little pressure left in the lines, anyway. Mine will still have some pressure 12 hrs or more after the engine is turned off.
CaptainObviousI
29
Apr 29, 2021 10:35 PM
PCLZ28
Dec 24, 2015 05:19 PM
ad356
Apr 16, 2015 05:38 PM
charchri4
Apr 14, 2015 06:40 PM
30thZ4C
Dec 26, 2014 05:09 PM
