fuel pump ring won't seat
Old Mar 15, 2007 | 02:47 PM
TJsrh420's Avatar
so i,ve been researching ths for like 2 hours now and all i cam up wit is my camaro has problems that no one else has.
my first problem is i have no idea what the black line goes to, come froms, or even attaches to. or even what the hell it is. and my other NEW problem is if you notice in the pic, my fuel pump is not centered in the retaining ring. why, i have no idea. it is a aftermarket pump that i bought from napa to replace. i bought the whole sending unit. what i have done so far is i lifted the pump out and bent up those two tabs that are on the sending unit so that they go in the cut outs for them and stay in better cause the miss if i didn't bend them up and the pump will be able to rotate clockwise. it just moves forward and backwards. no rotating. but when i tighten down the ring the pump can move from side to side or forwards and backwards. the ring to sending unit has about 1/8" gap. no lie. and my car reaks of gas. do i have o shim it, get a new sending unit, get a new ring, or just ATV it up?
if need a better pic just ask and i will get one better
peace,
TJ
Old Mar 15, 2007 | 03:02 PM
TJsrh420's Avatar
Old Mar 15, 2007 | 05:40 PM
You posted the same topic several months ago. Did you read the earlier responses, and follow up on them.
http://camaross.com/forums/showthread.php?t=491630
Read the post "stickied" at the top of the LT1/LT4 Engine Tech forum, regarding the policy on forcing a thread to the top ("TTT") without waiting at least 24 hours for responses. Waiting 15 minutes and pushing it back up is ridiculous.
Read the descriptions under the name of each forum, so you know what questions to post in which forums. A question regarding the fuel pump doesn't belong on "LT1/LT4 Engine Tech". PLEASE post only on the correct forum. I'll move it to the "Fuel and Ignition" foprum for you.
Old Mar 15, 2007 | 06:27 PM
The Engineer's Avatar
The pump assembly and pickup filter is slightly spring-loaded and presses on the bottom of the tank, which in-turn causes the lid with tubes to push-up.
Therefore you have to use some minor finesse and press down the lid and center the O-ring. Then place the ring bracket in place and start the nuts on the studs while holding the lid down. Maybe you need and extra set of hands (a helper).
You are apparently tightening the ring bracket without having the lid centered and down in-place.
WD
Old Mar 18, 2007 | 07:39 PM
TJsrh420's Avatar
i did have a helper and i tightened and removed the nuts about 10x and nothing. i bent the ring to get closer. still nothing. there is just a big gap. i kno i've posted something like this before but not about it not seating. but i did mention the gas smell but i just found this out.
but thanks for the help. i guess atv will have to do
Old Mar 21, 2007 | 11:13 AM
DirtyDan's Avatar
Just a heads up, if you use rtv silicone the gas will eat it and you will clog the new pump. Something in the re-assembly just hasnt gone right. Did you try loosening the fuel tank straps to see if a little more clearance would help you out?
cmyname1
Feb 19, 2015 08:38 PM
Scottyboy
Feb 11, 2015 10:28 PM
Jessie4tin
Jan 7, 2015 08:53 AM
ANDYZ28
Dec 29, 2014 09:13 PM
