Performance Switch?
Old Jan 4, 2007 | 10:22 PM
19z28camaro02's Avatar
Lightbulb Performance Switch?
Which Fourth Gen. had the performance switch? T/A wasnt it?
Old Jan 4, 2007 | 10:25 PM
shoebox's Avatar
Not sure if it was T/A only, but it was a Pontiac only thing.
Old Jan 5, 2007 | 07:44 AM
mmmchickenboy's Avatar
i remember reading about this a while back, and IIRC, camaro's have either the wiring for the switch, or the PCM has a pin for it. so theoretically you could rig up the same switch on a camaro, or a formula (if it's a T/A only feature).
Old Jan 5, 2007 | 07:58 AM
Fast4thGen's Avatar
My formula has it, so its not a T/A only thing.
Old Jan 5, 2007 | 01:10 PM
convertz's Avatar
It was a pontiac thing, camaros have the tables in the PCM for the performance shifting also, but you need a pushbutton to activate it. The wires are on a pair of connectors in the passenger side kick panel.
I think bret franker has the write up on how to do it, including an LED to see whn its activated, simple stuff if I remember correctly
Old Jan 5, 2007 | 02:47 PM
shoebox's Avatar
There is info on my site on how to wire it up on the Camaro.
Old Jun 19, 2007 | 04:02 PM
djk19's Avatar
Thumbs down
I can't find the wiring diagram for this on your site shoebox... I have a 95 Z and I NEED to find a way to disable that powe robbing system that it has. i love having it for wet weather but not all the time and NOT for launches. I have been screwed in races due to that crap too much to ever deal with again.
Old Jun 19, 2007 | 04:32 PM
djk19's Avatar
I can't find it on either site brents site or yours!! Help me out!!
Old Jun 19, 2007 | 04:42 PM
JAB's Avatar
JAB
Old Jun 19, 2007 | 05:09 PM
You're asking about the traction control system, and everyone else is talking about a shift "performance" button. The TCS system has a button to turn it off..... might explain why you can't find a wiring diagram.
Generally better to start your own thread than to highjack someone else's.
Old Jun 19, 2007 | 05:42 PM
djk19's Avatar
generally better to know that there is a diference with the tcs and performance button. didn't know before. now I do.
Old Jun 19, 2007 | 05:43 PM
djk19's Avatar
So Is there a wiring diagram of the tcs button because my car doesnt have one..
Old Jun 19, 2007 | 10:11 PM
shoebox's Avatar
If you don't have a button, you don't have TCS. You would need hudreds of dollars of additional parts to add TCS to your car. Most people that have it, disable it .
Old Jun 19, 2007 | 11:30 PM
djk19's Avatar
not listening. 95 camaro
has traction assist
has no button to shut it off
need to wire in button like pontiac has
button is responsible for traction control AND shift points
Who has the info?
Old Jun 20, 2007 | 01:25 AM
theratdude64's Avatar
are you sure your not callin the "low Traction" light Traction control? When I first got my car my eye went streight to where I knw the TCS button to be and it wasnt... but when I turned the key to on and all the guage lights lit up it said "LOW TRACTION" and i thought wtf, i dont have it... Turned out to be ABS.
I still have yet to do this switch mod I cant find a switch I like :P
