Which plugs and wires?
Old Nov 27, 2006 | 12:19 PM
gil'97cloneSS's Avatar
Just wanted your guys opinion on which plugs and wires would be best for my LT1. Thanks.
Old Nov 27, 2006 | 02:19 PM
StephenDeli22's Avatar
AC Delco's
Old Nov 27, 2006 | 04:58 PM
MysticTeal95Z28's Avatar
Originally Posted by StephenDeli22
AC Delco's
I hope he has a lot of money.
I went with NGK TR55 plugs and Taylor Spiro Pro Spark Plug Wires, no regrets. AC Delco wires would have costed me $ 107 at O'Reilys...
Old Nov 28, 2006 | 03:16 AM
Thanks for the input. Also what did you gap your plugs at.
Old Nov 28, 2006 | 07:11 AM
2000GTP's Avatar
Gap them at whatever your underhood specs sticker says. I believe it is .050 As for suggestions of what to go with, I also am a big fan of the NGK plugs and have also had good luck with the Taylor wires.
Old Nov 28, 2006 | 11:25 AM
byrons1502's Avatar
love the ngk or delco plugs. can't beat the taylor wires for the money and quality, they are the only wires i have used that actually fit without being ten miles to long. i own a repair shop and have tried everything. just drove 230 miles to pick up customers car that died and found the msd coil wire went bad. third time i have seen this on other cars
Old Nov 30, 2006 | 01:04 PM
I think it was you that reccommended that Taylors to me and for the price they are AWESOME. Good fit as far as their length goes too.
Edit here is a thread from when I was asking for advice:
http://web.camaross.com/forums/showthread.php?t=483001
Don't be an idiot like me and buy the Taylor Thundervolts, especially if you have a stock ignition, they're overkill! The Spiro Pros are the ones to go with.
Old Nov 30, 2006 | 02:11 PM
2000GTP's Avatar
Yeah, the Spiro Pros are very good wires. Its what I was using.
Old Dec 1, 2006 | 04:04 PM
69gto96z's Avatar
I have the NGK TR55's and Taylor 8mm spiro pro wires, I love em.
Old Dec 1, 2006 | 05:00 PM
matLT1's Avatar
I liked the results of my MSD wires. Kind of a PIA to install but well worth it. The price isn't too bad either.
Old Dec 14, 2006 | 02:34 PM
mzgp5x's Avatar
I use MSD, and the Zex plug. I had NGK tr6 and fowled them alot. (383-FI). The Zex plug has solved my problem. Been working on my fuel map also.
Old Dec 17, 2006 | 06:48 PM
byrons1502's Avatar
do you happen to have part #'s and heat range comparisons. need to go 1-2 steps colder
Old Dec 18, 2006 | 08:22 AM
mzgp5x's Avatar
Don't know the heat range, but, if you go to zex.com, they have information on the plug. They have a selection for FI and NA. My NGK's were fouling alot in a cold start-up conditon. I ended up changing the injector vs. voltage cal @ low volts, and, the open afr cal @ cold temps (higher afr than stock @ MAP/ Low temp. - 13 to 14). The larger the injectors are, I have found this is necessary with my set-up (running 72# now).
Hope this helps.
PCLZ28
Dec 24, 2015 05:19 PM
charchri4
Apr 14, 2015 06:40 PM
eanhl2004
Apr 4, 2015 12:01 PM
IRABuss
Sep 7, 2011 09:08 PM
gh0st
Sep 1, 2002 10:24 AM
