Does this exsist?
Old Sep 30, 2006 | 08:27 AM
NVetro's Avatar
Does this exsist?
ok, we all know that changing jets sucks for nitorus kits. Is there a device that will allow you to just run some large jets (irrelevent) and have a controller in the car to select 75 shot, 100, 125, 150, etc.. et.. etc.. So i dont have to get out of the car.
Old Sep 30, 2006 | 09:25 AM
blackztpi's Avatar
Re: Does this exsist?
i don't believe there is anything out there for nitrous, but i know there aer such devices for other things....now, the hard parts is finding one that will hold 1200 psi.
Old Sep 30, 2006 | 10:27 AM
rskrause's Avatar
Why would you have to frequently change jet sizes?
Rich
Old Sep 30, 2006 | 10:49 AM
Install a two stage system, and set it up so you can choose stage 1, stage 2 or stage 1+2..... that gets you three different levels.
Old Sep 30, 2006 | 12:44 PM
97formulakid's Avatar
what he said
I'm thinking about doing a dual stage so I can spray a small shot off the line then a bigger one up top.
Also, it would come in handy when racing because if I didn't want to run all the juice I wouldn't have to.
Old Oct 2, 2006 | 04:56 PM
1SlowFormula's Avatar
I guess you could also get a controler and put in a larger jet and tell it to only give x percent...
Such as setting it up with 150 jets and tell it to spray only 50% then you should only get a 75 shot and those are adjustable from in the car...
Then again doing it this way may shorten your solenoids lifespan...
Old Oct 3, 2006 | 10:55 AM
Chopstix's Avatar
Another vote for a progressive controller, if you are spraying more than 150......helps with keeping wheel spin or wheels stands under control.
For small shots there is less need to adjust Nitrous levels. It takes me less than 2 min. to change jets. Takes longer to get a wrench and the new jets than to install.
Old Oct 3, 2006 | 10:59 AM
rskrause's Avatar
I use a single stage with up to 250hp. Depends on the combo, I guess.
Rich
Old Oct 3, 2006 | 11:43 AM
srsnow's Avatar
The thing to remember about progressive controllers is that it is a % of what the solenoids can flow not what it is jetted to necessarily
Old Oct 5, 2006 | 09:42 PM
black97z28LT1's Avatar
damnit! beat me to it, lol
surreybrad
Jul 5, 2015 10:36 PM
luther4653
Apr 13, 2012 01:47 PM
Z28RV
Jan 12, 2004 06:07 PM
D James
Sep 24, 2003 11:42 PM
