HELP!....My E-brake doesnt work.....HELP!
Old Jul 3, 2006 | 04:57 PM
87350TPI's Avatar
My ebrake doesnt do anything.....I like to get nutty in my 87 Iroc 350TPI With posi but i cant drift because my ebrake doesnt work. if anyone has any ideas please help.
Old Jul 3, 2006 | 07:14 PM
JJJ93z's Avatar
Re: HELP!....My E-brake doesnt work.....HELP!
you might wanna buy a hanes repair manual for your car, they have detailed information on how to address, and repair many things on your car so you can get back to being nutty
Old Jul 5, 2006 | 09:17 AM
respectirocz's Avatar
first get under the car and take a look at the cables
if you have rear drums, jack it up take off one wheel at a time and have someone pull the ebrake as you watch the assembly
if it moves slightly but not far enough, then it just needs to be adjusted, may have stretched the cable over time
if it doesnt move at all, you may have snapped a cable
next, follow both cables from either side of the axle to where they meet in the driveshaft tunnel above the driveshaft and torque arm
make sure none of the cables snapped
make sure the cable from the e-brake handle to this union hasnt snapped either
if all cables are good and have not snapped, then you have to tighten the adjuster nut on the union
major P.I.T.A.
i recommend getting a ratcheting 13mm wrench to use with either vice grips or a 1/4 in open end wrench
i advise you to unbolt the driveshaft and even take it out before you attempt to get your hands in there, i'm a fairly thin guy and i had a terrible time doing this
BoobSter-lt1-z
Feb 7, 2004 03:50 AM
Ferocity02
Sep 11, 2003 02:37 PM
ERIK93Z
Sep 4, 2003 06:06 PM
ERIK93Z
Sep 3, 2003 01:33 AM
ip305
Mar 6, 2003 04:57 AM
