Cost of repairing/balancing Carbon Fiber Driveshaft
Old Jun 29, 2006 | 02:19 PM
user 647483's Avatar
Has anyone had to have a CF shaft repaired/balanced?
I found one for sale pretty cheap ($100), but it needs a new yoke and
the surface has a repair (and needs to be rebalanced).
I don't need a CFDS; but if I can pick one up cheap, I wouldn't mind running one.
Old Jun 29, 2006 | 05:16 PM
rskrause's Avatar
Re: Cost of repairing/balancing Carbon Fiber Driveshaft
You not only don't need one, you don't want one. It's probably possible to make a great CF DS for an F-body. But AFAIK such a shaft would cost thousands of dollars. Consequently, no one is making one. It wouldn't sell because the gains would be small and the price would be high. What is on the market is trash, from everything I have seen.
Rich
Old Jun 29, 2006 | 05:41 PM
Thanks for the tip.
The LS1 shaft should handle 400rwhp without a problem right? (on an A4)
Old Jun 29, 2006 | 06:51 PM
joe-96z1le's Avatar
The CF driveshafts seem pretty popular at my local speed shop. What problems in particular have you seen? I was considering one since I seem to be getting a bit of vibration from the aftermarket steel DS I recently purchased new. My aluminum one was very smooth but I didn't feel comfortable using it at my new HP level.
Old Jun 29, 2006 | 09:54 PM
rskrause's Avatar
Originally Posted by James Montigny
Thanks for the tip.
Yes, it should.
Why I don't like CF DS: I have seen a couple fail, they are much more expensive than the proven CM shafts.
Rich
Old Jun 29, 2006 | 11:09 PM
My ACPT CF DS fell apart while the car was being driven from the engine shop to the body shop (1 mile) on a "just enough to keep it running" tune. Listen to Rich. If you really, absolutely have to have one, go to Mark Williams. Make sure your credit card limit is healthy. They are useful for solving critical frequency problems on unusual length setups, with engines capable of very high RPM. Other than that, they are of limited value.
Novo
Jun 14, 2016 02:58 AM
CARiD
Sep 30, 2015 05:44 AM
Sep 11, 2015 09:44 AM
Daluchman1974
Sep 11, 2015 06:12 AM
gonzo275rltw
Sep 5, 2015 06:26 PM
