Fuel pump?
Old Apr 5, 2006 | 10:08 AM
TRIPOWER's Avatar
Fuel pump?
what's a good replacement pump? stk is a 190lph is a 255lph to much? im not making crazy hp but just bolt on's and a hot cam. can i just get a pump or do i need the harness?
Old Apr 5, 2006 | 10:27 AM
Z28SORR's Avatar
Re: Fuel pump?
If you haven't changed the fuel system, bigger line, pickup, etc. And/or your not having pressure problems, why do you need a new pump? Check your fuel pressure at WOT under load.
Old Apr 5, 2006 | 10:49 AM
TRIPOWER's Avatar
Re: Fuel pump?
The reason is the car has over 100k and just looking for an upgrade
Old Apr 5, 2006 | 03:48 PM
2000GTP's Avatar
Re: Fuel pump?
The Racetronix pump is a cheap upgrade and is rated at 255lph. You can get them for around 125 bucks.
Old Apr 5, 2006 | 07:39 PM
BadgeZ28's Avatar
Re: Fuel pump?
I am using a Walbro 255 pump. It requires minor adapting and emits a audible operating noise in my car.
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
Black Sunshine/ 00SS
Sep 15, 2002 10:08 PM
