Power Passenger Window Problem
Old Mar 14, 2006 | 09:54 PM
BlazeV638's Avatar
Passenger Window button will work to roll down the window but i have to use the drivers side passenger button to roll the window back up. Could this be a wiring issue or the window motor? Too cold to pull the door panel off right now but i'm up for suggestions.
Old Mar 15, 2006 | 12:36 AM
96camaroSS's Avatar
Re: Power Passenger Window Problem
If the switch works one way but not the other then I would think the problem is most likely in the switch. If the motor were bad it wouldn't matter which side you tried to roll it up or down from. If you have a DVM, pull the switch away from the door panel and turn the key to ACC. This should get you 12vdc to the switch. Then check to see if voltage is making it through the switch to the window motor.
I know there are several wires on that switch so having a service manual that shows wiring diagrams for the chassis electrical would really help to make your troubleshooting easier.
Old Mar 15, 2006 | 07:56 AM
scottso's Avatar
I was having sporadic problems with my pass side window not working from the drivers side - I disconnected the plug from the pass side switch - cleaned the pins, a little dielectric grease and reseated it tightly and the problem went away. I would try that first.
Old Mar 15, 2006 | 02:22 PM
BlazeV638's Avatar
Thanks i will definately try that today, i figured it wasn't the motor because it still worked but i didn't know where else to start. Thanks for the suggestions
Manaz101
Aug 26, 2002 04:26 PM
slothgrant
Aug 22, 2002 03:01 PM
gmeapush
Jul 29, 2002 08:17 AM
gmeapush
Jul 21, 2002 07:53 PM
Manaz101
Jul 18, 2002 09:39 AM
