P1371
Old Jan 27, 2006 | 12:56 PM
RICEFEDZ28's Avatar
P1371
What is this code? Car drives perfect for about 6-7 miles then dies. Try to start back up it just cranks. Let it cool down for 30 mins and it starts like noyhing ever happened. Drive around for 6-7 miles does it all over again. The code i'm pulling is a 1371. Can't find any info.
Old Jan 27, 2006 | 01:18 PM
2001NBMZ28's Avatar
Re: P1371
I looked it up but can't help on the fix - P1371 Distributor Ignition (DI) Low Resolution Circuit.
Old Jan 27, 2006 | 01:54 PM
blitzer454's Avatar
Re: P1371
I think that is an indication that your opti-spark is on its way out.
Old Jan 27, 2006 | 11:15 PM
Re: P1371
You might want to add basic info like the year of your car so people don't have to go to cardomain to find out.... codes for an LS1 would not be the same as an LT1 for example. In your LT1, that loss of low res pulse from the Opti, an it will prevent the car from starting, since the PCM shuts off the fuel system when it can't find the low res pulse pattern. Sounds like the optical sensor is overheating.
Old May 26, 2006 | 03:24 PM
1996z28m6's Avatar
Re: P1371
how would you solve this problem?
Old May 27, 2006 | 08:13 PM
Re: P1371
First verify that its due to the optical sensor overheating, and not come fluke coincidence with the wiring harness or corroded connectors. Then replace the Optispark.
Old May 30, 2006 | 09:12 PM
hey01's Avatar
Re: P1371
I've had this happen
driving..............off, pull over..cranks up........ eventually it will get so bad you won't be able to crank it without a full cool down and it will only drive 5 miles or so untill it shuts off again. just like injuneer is saying it sounds like that damn sensor is getting to hot and pissing out.
fastcam91
May 7, 2010 05:22 AM
IPrice
Feb 15, 2009 02:00 AM
Domss2000
Jun 29, 2008 12:13 PM
JimboManJones
Mar 11, 2006 07:46 PM
TCamaroSS
Aug 3, 2004 04:16 PM
