Q's about installing a new fuel pump
Old Oct 18, 2005 | 08:21 PM
Blown_Red_97z's Avatar
I have been doing some searching, and have found that the easiest way is going to be to cut the access hole. First off, what are the right tools. I am guessing probably just a dremel and some hand tools. The new pump is a Holley 255, almost identical to the Walbro, but do I need any sort of adapters for this pump to work? Is there anything I am missing? Do I need any sort of new gaskets or other parts? any other good writeups? I checked shoebox's site, I didn't see one on there. TIA!
Old Oct 18, 2005 | 08:29 PM
FastZinTennessee's Avatar
Re: Q's about installing a new fuel pump
I'm thinking a dremel would take a while. Do you have access to an air powered die grinder? That and a cut-off wheel would make pretty quick work of it. Don't forget the eye protection as well, when you get a small piece of metal in your eye from using a die grinder it tends to cause irritation, making it look like you've been crying, and people tend to look at you like "what the hell is wrong with that guy?!" <don't ask me how I know>
Old Oct 18, 2005 | 08:33 PM
snakeatinZ's Avatar
I have not done it through the access hole, But I have droped the tank out of the bottom. My god, what a pain in the arms.
Old Oct 18, 2005 | 08:36 PM
94Z28WP's Avatar
I didn't use a Dremel.. I took the wimpy way out and drilled a large hole in two corners and used tin snips to cut it.. HERE'S my thread with links how to do it.
Old Oct 18, 2005 | 08:49 PM
Just checked in the garage since my GF's dad has all of his tools here. Theres no air powered die grinder, but there is an electric hand held mikita grinder. I am pretty sure that would kick the crap out of the dremel out there, just have to be careful and make sure I measure the cut properly and not get crazy.
Old Oct 18, 2005 | 09:14 PM
Fastbird93's Avatar
I did a full write up seen HERE.
I used a dremel, which didn't take very long at all. Maybe 10 minutes tops, and that was mostly to change cutoff wheels.
Old Oct 18, 2005 | 10:35 PM
What about some sort of harness, like a painless wiring harness. I noticed that there is a kit that from thunder racing that has the pump and the wiring harness. If I have a holley pump, can I just order this harness, or how much work has to be done to adapt the wires to the ones in the tank?
Old Oct 18, 2005 | 10:49 PM
snakethis69's Avatar
i just did this, and i have some tips. i did the dremel method. took forever cause i kept grinding wheels away and/or breaking them. after that spray the quick releases down with carb cleaner or something. undo everything. i tossed the bucket but i coulda used it if i wanted. i chose to just use two hose clamps of medium size and put it on that way. make sure you get 50PSI or higher fuel/emission hose and make sure your tighten your clamps down very tight. i had 4 hoses come off and/or break on me. now i have no problem other then blowing the **** out of my tranny
Old Oct 19, 2005 | 02:57 PM
thanks for all of the info, but anyone have advice about the whole wiring thing? Its not just plug and play right, I need to get that adapter?
Old Oct 19, 2005 | 05:34 PM
your pump should come with a connetor with two wires coming off it. just replace the old connector withthat one. use crimp barrels.
Old Nov 12, 2005 | 04:46 PM
chevroletfreak's Avatar
What type of glue is used for the pump cup housing?
What type of grease is used for the o-rings?
Old Nov 12, 2005 | 05:01 PM
The racetronix pump I got (pump only, no harness) came with glue for the cup housing and lube for the o-rings. I'm not exactly sure what it was though....
Old Nov 14, 2005 | 02:42 AM
Racetronix's Avatar
Please e-mail support@racetronix.com or contact your dealer for the information you require.
Scottyboy
Feb 11, 2015 10:28 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
