LS1 DS yoke on LT1?
Old Sep 23, 2005 | 11:38 AM
seawolf06's Avatar
LS1 DS yoke on LT1?
Would a DS from an LS1 fit onto an LT1 yoke with an LT1 u-joint, or do you need an LS1 u-joint? I tried posting this question in an existing post, but the subject was misleading and no one answered. Thanks.
Old Sep 24, 2005 | 09:17 PM
crazypurgatory's Avatar
Lightbulb Re: LS1 DS yoke on LT1?
The LS1 DS and the LT1 I believe are the same.
Look here.
http://www.tacreationsusa.com/other_rear_parts.htm
Chris G.
Old Sep 25, 2005 | 03:04 AM
seawolf06's Avatar
it has different measurements for the 93-02 steel DS for T-56 and the aluminum DS for 98-02. the yoke length for the 93-02 steel is much longer. is this right? i thought the DS was the same no matter what tranny you had.
Old Sep 25, 2005 | 08:22 AM
shoebox's Avatar
The complete driveshaft can be swapped without a problem as the overall length is practically the same. If you want to go swapping LS1 and LT1 front yokes, you might get into trouble as they are not the same length.
Old Sep 25, 2005 | 07:10 PM
seawolf06's Avatar
that's what i was worried about. thanks shoebox, you're the man as always.
Old Jan 14, 2007 | 01:40 AM
Bow94z's Avatar
so what has to be done to make the LS1 drivesahft fit on the LT1?
the LS1 shaft im lookin at is complete, so could i just swap the two?
Old Jan 14, 2007 | 01:51 AM
seawolf06's Avatar
You can swap them directly as long as both are a one-piece shaft.
rideordie
Nov 5, 2019 04:52 PM
ddr698
Jan 31, 2015 10:58 AM
