Transmission cooler?
Old Jun 6, 2005 | 04:58 AM
LT1 POWR's Avatar
Would my car have a tranny cooler? How would i know or find out.
Old Jun 6, 2005 | 05:13 AM
BigEvil's Avatar
Re: Transmission cooler?
If you or the previous owner didn't put one on, then no it wouldn't. Look in front of the radiator (towards the nose), it would probably be in that area.
Old Jun 6, 2005 | 05:45 AM
Brent94Z's Avatar
Super Moderator
It'll have a factory tranny cooler (built internal to the radiator) but may not have an aftermarket one. Here are some pics of an aftermarket tranny cooler...
http://www.bfranker.badz28.com/94Z/trannycooler.htm
Old Jun 6, 2005 | 05:56 AM
LT1 POWR's Avatar
so it has a stock tranny cooler.
Old Jun 6, 2005 | 06:21 AM
rskrause's Avatar
Yes.
Rich
Old Jun 6, 2005 | 04:27 PM
LT1 POWR's Avatar
Is it any good. If i wanted to do a shift kit and maybe a stall would this stock cooler support it.
Old Jun 6, 2005 | 05:04 PM
2001NBMZ28's Avatar
If you do a stall do an aftermarket cooler - cheap and easy to install. Some manufacturers say you don't absolutely need one, but like I said they're cheap, and will help keeps the temps down.
Old Jun 9, 2005 | 03:01 PM
1quickTA's Avatar
Would a tranny cooler help an M6 all that much??? I have noticed that pretty much everyone who talks about them has an auto and I was just wondering because it seems like it would.
Old Jun 9, 2005 | 03:45 PM
LUDA0840's Avatar
Will a cooler double the life of my tranny? How much are they usually?
Old Jun 9, 2005 | 05:28 PM
rskrause's Avatar
A manual tranny doesn't generate near the heat of an automatic. And it has no pump to circulate fluid. So, a cooler isn't needed and an entirely different setup would be needed. There are manual transmissions which require external cooling (road racing, maybe others) and I believe these use some sort of external pump, sort of like a "dry sump" engine oiling system.
Rich
Old Jun 9, 2005 | 09:39 PM
SVThuh's Avatar
Funny you should mention a manual trans cooler..
http://frrax.com/rrforum/index.php?act=ST&f=8&t=4749&
I am going to do a poll on this board as well..
Sep 27, 2015 01:55 PM
cristian1311
Sep 12, 2015 08:16 PM
Daluchman1974
Sep 11, 2015 06:12 AM
92_RS_305
Sep 8, 2015 07:47 PM
rideordie
Sep 7, 2015 08:22 AM
