some V6s Qs
Old Mar 28, 2005 | 04:29 PM
2001 B4C's Avatar
some V6s Qs
alright
1) how similar are the bell housing patterns on a 3.4 and the later 3.8 in the camaros?
2) only answer if you know for sure please, are the 3.8 bolt patterns the same for the fwd cars and the rwd cars..
i have a fwd motor and i need to know if i could use a 3.8 or a 3.4 bell housing and/or transmission with the motor, i dont want to call junkyards becuase as soon as they hear camaro everything goes up 50% i am just needing to know if the bolt pattern for the trans is the same
Old Mar 29, 2005 | 01:24 PM
Teufel Hunden's Avatar
Re: some V6s Qs
The bolt patterns between the 3.4 and the 3.8 are not the same. The 3.4 is a 60º block, where as the 3.8 is a 90º block.
Old Mar 29, 2005 | 01:36 PM
Wolfie's Avatar
Re: some V6s Qs
half true, the 3.4 is a 60* and the 38 is a 90*, but they both have the same bellhousing,60* pattern, but the starter is on a diferent side on each motor so you need a 3.4 bellhouse with a 3.4,and a 3.8 bellhouse with a 3.8
95redLT1
39
Jul 26, 2009 02:02 PM
Decap92RS
V6 Tech
May 15, 2007 01:04 PM
TheV6Bird
Mar 25, 2007 11:10 PM
guionM
60
Dec 24, 2006 08:52 AM
