Codes question
Old Mar 16, 2005 | 09:58 PM
nikeman211's Avatar
Codes question
I read the codes for my car today and got three codes and I really don't know what they are. I would appreciate it if someone could tell me what they are.
code 36-Ign system problem loss of high Res pulse signal.I think that this one is my optispark.
code 42-Ign system problem elec spark timing (EST) is grounded.
code 73-Transmission force motor current problem.
Old Mar 16, 2005 | 11:11 PM
Re: Codes question
From Shoebox's LT1 OBD-I code list:
DTC 36 = Distributor ignition system (faulty high resolution pulse or extra low resolution pulse detected) - Yes, this is the Opti. The engine will run OK with this problem, because the PCM can default to using the low resolution pulse. You will just lose a little timing accuracy.
DTC 42 = Ignition Control (IC) circuit (shorted or grounded circuit) - This is a fairly complex problem to diagnose, relating to the Opti, the IC Module, the coil and the signal from the PCM. I believe Shoebox has the diagnostic logic tree on his Tech Pages.
http://shbox.com/1/4th_gen_tech1.html
DTC 73 = Pressure Control Solenoid (PCS) circuit (current error) - Obviously the auto tranny
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
cmdeshon
Dec 27, 2014 10:06 AM
johnsocal
Aug 29, 2002 10:01 AM
91Bird305
Aug 5, 2002 01:39 PM
