exhaust manifolds get RED HOT!
Old Nov 23, 2004 | 06:30 PM
Jaswir's Avatar
just noticed on the left side of engine that the manifold gets super hot i mean it glows! at night!! and burning my spark plug wires and melting them! plus the car doesnt run good at all its real sluggish at take off and hesitakes alot durning aceleration... like theres a blockage also i have had the manifold gaskets replaced and i think before this it ran like that but no where near as bad as now... any idea what i should do i wanna fix it my self
Old Nov 23, 2004 | 06:34 PM
rokudan's Avatar
Re: exhaust manifolds get RED HOT!
Sounds like you may have a bad head gasket. Water is getting leaked through to the compression chamber and burned off. Time for an upper end rebuild, and if you keep driving it like this you will kill the bottom end as well..
Old Nov 23, 2004 | 08:06 PM
86camedcamro's Avatar
to me it sounds like timing.
Old Nov 23, 2004 | 08:17 PM
Ragtop-87's Avatar
I think that the Cat converter is plugging up. You might want to drill a hole before the converter to see if you have a lot of pressure coming out of the hole. If so just cut it out and replace with a pipe if you don't have emmissons check where you live.
Old Nov 23, 2004 | 09:25 PM
Jaswir's Avatar
acutally i checked that out... pulled the coverter off and that wasnt the problem
Old Nov 23, 2004 | 09:31 PM
ChevyTuffD.A.'s Avatar
Sounds to me like the car is running really lean. The less fuel u have, the more your combustion temps raise. I have an LT1 and I have read about this happening quit often.
Old Nov 23, 2004 | 09:36 PM
rokudan's Avatar
I dont think it is that the car is merely running lean. This went through my head also, but was negated by the fact it is only happening on one side.. I've seen it before, you may have a blown head gasket and are losing coolant, thus you are overheating... Run a compression test, I would be willing to bet at least one of your cylinders is low on compression.. If so, head gasket.. Either way, stop driving it until you figure it out.
Old Nov 24, 2004 | 06:44 AM
The basic thing to realize here is that obviously the combustion temperatures are WAY too high. I am not too familiar with the fuel injection set-up on your motor, how many injectors do u have??
Old Nov 24, 2004 | 08:51 AM
my dibs are on the timing i went thro this once befor
Old Nov 24, 2004 | 09:20 AM
Jaswir's Avatar
my engine temp it self if fine and has never overheated... also my coolant is fine and isnt leaking... alot of people say its the timing i think im going to get that checked out first... thanks for the help
Old Nov 24, 2004 | 02:18 PM
RedIrocZ-28's Avatar
The left side of your engine is the side without an Oxygen sensor. If it was a timing issue then the right side of your motor would glow too. However since timing is a static variable, and fuel delivery is not, I would check the fuel injectors or fuel rails for blockages on that side of the motor. Or a head gasket. You have to rule out all possibilities and pay no attention to the things that won't cause the problem. If it was timing, the whole motor would have the headers glowing, not just 1 side. Unless you have some weird dual distributor setup
Old Nov 24, 2004 | 03:30 PM
I am willing to bet that whatever supplies that side of the engine with fuel is malfunctioning and causing a lean condition.
Old Nov 24, 2004 | 04:35 PM
Rice Killer87's Avatar
its running lean on that bank of cylinders.
w/ the car running,put ur fingure on each injector and see if u can feel the pulse for each one on that side. if u can,they might need to be cleaned/replaced.
if u cant hear/feel the pulse,check to see if their gettin power.
Old Nov 24, 2004 | 08:51 PM
Jaswir's Avatar
both have glowed before, way before it runs like it does now.... i know the right does get hot but i dont think it does as fast... think im going to get it looked at... really not sure on how to do some of the things you guys have mention on here... with the injecters and fuel rail etc... thanks for the help tho
linz
Oct 22, 2015 07:59 AM
Chris Anderson
Jan 27, 2015 08:30 AM
spearous
Jan 12, 2015 11:03 AM
ModdedNerd
Dec 14, 2014 10:28 AM
