Jsut converted 97-02 to 93-96 tail lights
Old Oct 7, 2004 | 04:11 PM
MustangEater82's Avatar
And it looks alot better.
As for the wiring, I added a 3rd wire to the turn signal socket like Dark angel suggests here.
http://web.camaross.com/forums/showt...ght=conversion
but I used a tap in and tapped it into the brown wire, which is the "headlight" wire, so the lights are at half bright whenever the headlights are on. But when I activate the turn signal, its goews between, half bright to bright, flashing.
Everything else is the same.
I am kinda thinking of running a wire from turn signal to the brake socket, so when the turn signal is on the brake light flashes too. I woudl have to run a diode in the line, so that when I brake and use the turn signal that the turnsignal will flash and the brake woudl be solid. Not sure if I am going to do this but would be cool.
Old Oct 7, 2004 | 04:59 PM
meissen's Avatar
Re: Jsut converted 97-02 to 93-96 tail lights
glad to see you made good use of the tail lights.
Old Oct 7, 2004 | 10:48 PM
yep and I love 'em!
thanks!
Klypto
Parts Wanted
Apr 22, 2015 07:08 AM
Caps94ZODG
25
Oct 2, 2003 06:30 AM
Caps94ZODG
10
Sep 9, 2002 12:08 AM
Caps94ZODG
Sep 7, 2002 10:09 PM
Caps94ZODG
18
Aug 30, 2002 10:46 AM
