flowtech cutout 3'' slip on "WIll THIS FIT?"
Old Aug 2, 2004 | 11:32 PM
SSHORTT's Avatar
will this fit on my stock exhuast system anywhere?
Old Aug 2, 2004 | 11:45 PM
jchevy's Avatar
Re: flowtech cutout 3'' slip on "WIll THIS FIT?"
What do you mean by 3" slip on. I know a normal 3" cutout will slip over the stock 2 3/4" 4th gen I-pipe, LT1 cars anyway.
Does the slip on mean that is a 3" cutout flared to slip over 3" pipe?
Old Aug 3, 2004 | 12:16 AM
SSHORTT's Avatar
He had it on here a while back....
http://web.camaross.com/forums/showthread.php?t=288198
will it fit?
Old Aug 3, 2004 | 12:30 AM
jchevy's Avatar
That link is to a high flow cat, not a cut-out. If its a cat you are looking for you need to know what size your y-pipe is, my guess would be that an exhaust shop can make it fit with no problems.
Old Aug 3, 2004 | 12:32 AM
SSHORTT's Avatar
I meant this one
Old Aug 3, 2004 | 12:34 AM
SSHORTT's Avatar
Thumbs up Re: flowtech cutout 3'' slip on "WIll THIS FIT?"
http://web.camaross.com/forums/showthread.php?t=286002
Old Aug 3, 2004 | 12:36 AM
jchevy's Avatar
Yup, it will fit in the I-pipe, which is where you want it i assume. Its where 99% of people put them, including me. The other 1% has true duals and runs two of them, one off of each collector.
Old Aug 3, 2004 | 12:50 AM
SSHORTT's Avatar
If i get this cutout will i ever need to put in a cat-back exhaust or does this get the same results with the stock pipes. and BTW thanks for all the advice
Old Aug 3, 2004 | 12:53 AM
jchevy's Avatar
I dont have a cat-back, just swapped out the muffler for the more agressive sound oun the street. open up the cutout at the track for preformance.
If you have cats you will probably be able to run the cut-out open all the time. Its way to loud with no cats and headers, also sounds like crap.
Old Aug 3, 2004 | 12:59 AM
SSHORTT's Avatar
how much difference can you feel with it opened up?
Old Aug 3, 2004 | 01:16 AM
jchevy's Avatar
It will actually feel like it made it slower, you will lose some low end tq, but will increase peak power.
Just do it, if you dont like it, cap it, you are out $35 for the cut-out and $30 for the install.
70rs00z-28
Sep 6, 2002 08:13 AM
phantasm99
Aug 28, 2002 11:01 PM
Speeds8erM-1
Jul 28, 2002 06:18 PM
MYT30TH
Jul 28, 2002 08:47 AM
Speeds8erM-1
Jul 18, 2002 11:36 PM
