need to replace fuel pump
Old May 15, 2004 | 04:42 PM
RED82TA5.7L's Avatar
whats a good one to buy online.. for less then 100 bucks.. this is for the 82 T/A and it has TPI. i dont want to have to do any modification.. will all years work? jegs has one for 150ish but says its for 85+. thanks
Old May 15, 2004 | 09:20 PM
xeroxed's Avatar
85+ is the years jegs lists for tpi because 85 was the first year for tpi. that pump should work without a problem.
Old May 15, 2004 | 09:46 PM
ok thanks.. just wanted to make sure they didnt change anything with the pump..
Old May 15, 2004 | 09:47 PM
tom2's Avatar
Get and AC or Carter at Advance auto for under a hundred. You're right to get a good pump, that job is no fun.
Old May 15, 2004 | 09:59 PM
aklim's Avatar
I'd get a good one like Walbro. Pay a little more now and when you need the fuel later, you will have it. The removal of the tank SUCKS. I'd rather not do it at all. I changed a perfectly good stock pump when I changed my rusted tank just because I didn't want to have to do it all over again.
Old May 15, 2004 | 10:38 PM
stanghunter211's Avatar
Hey man, aren't you using an inline pump? You might have a problem with swapping pumps if you are going to an intank since the 82 prolly did not have an EFI sender... Just a thought. Anyways, I got my walbro on ebay for 90 bucks brand new, its well worth it. I am going to be doing my tank/pump at the end of the month myself
Will
Old May 16, 2004 | 02:43 AM
it used to be CFI.. and i put the inline in to boost pressure.. been working fine for 2 years. till the intank one went out just wanna replace it and keep the inline, if i dont have to with the new pump ill just take it off.. my moms been driving it so she dont care if its running right.. she just wants to be able to drive it again lol, i dont want her to drive it but i have no choice, cause my dad "helped" me get the 96, but i got the 96 to have fun in so i dont mind if she breaks the 82 , the int has gone to crap since shes been driving.. probably cause i took so much care of it when i drove it but now i spend all my time on the 96
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
Jessie4tin
Jan 7, 2015 08:53 AM
ANDYZ28
Dec 29, 2014 09:13 PM
