Fuel problems?
Old Apr 9, 2004 | 10:40 PM
Ramune's Avatar
Fuel problems?
Tonight I was coming home from work and my car started acting like it had a messed up carb or something. In the lower gears it seemed to struggle to keep the engine running. Is this a fuel problem, or is this the great misfire problem that 97's have?
Old Apr 10, 2004 | 12:35 PM
oil pan 4's Avatar
How many miles does it have?
Has the fuel filter ever been changed?
Dirty fuel filter problems come on fast usaly.
Old Apr 10, 2004 | 01:52 PM
Ramune's Avatar
It has 25000 miles. I doubt the fuel filter has ever been changed (I bought it used). This problem did come on fast, I drove it to work, but when I went home, it started clunking. Oh well, it's in the shop now.
Old Apr 10, 2004 | 08:44 PM
oil pan 4's Avatar
That hapend the same way on the last 2 cars that went down because of a fuel filter.
1 was an RX7 and the other was a skyline both guys came to work in the morning and when they left that day there cars ran like **** when the broke, hmmm.... right about the time the tempture started staying above freezing more than a day at a time.
There cars broke down about 2 days apart.
Old Apr 10, 2004 | 10:50 PM
Ramune's Avatar
Wow, that sounds like me. I hope I'm not paying 85 bucks an hour to have a fuel filter replaced. Wait... maybe I should hope that's all that's wrong... but... argh!!! I'm so confused!
Old Apr 11, 2004 | 05:23 AM
oil pan 4's Avatar
Don't worrie about paying labor 4 an RX7 fuel filter install it was all most $100 for just the filter.
You can get a new one for about $40 and put in your self with just plyers and a screw driver most likely.
Old Apr 11, 2004 | 05:33 PM
ImportKILLER's Avatar
Fuel filter = > $10
One hour, with a beer break in between, job. Tops.
Old Apr 12, 2004 | 03:22 PM
Ramune's Avatar
Well, turns out it was plug number 6. Changed the fuel and air filter for good measure.
Old Apr 19, 2004 | 12:28 PM
Need4Camaro's Avatar
If it happens again, it may be your coils but I doubt it at 25,000 miles... did you change all 6 of your plugs or just the misfiring one?
Old Apr 19, 2004 | 04:06 PM
Ramune's Avatar
Just number 6. I'm going to go along with the FAQ posted here and get some new wire covering.
Dec 1, 2016 05:37 PM
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
Scottyboy
Feb 11, 2015 10:28 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
