mufler question
Old Sep 15, 2002 | 10:02 PM
crazymanz28's Avatar
mufler question
Ok I have a 79 Z28 with stock exhaust and stock Th350 trans. I was woundering when I put my full length headers on, will I be bale to bolt these mufflers striaght up to the headers : http://www.jegs.com/cgi-bin/ncommerc...00&prmenbr=361 without hitting the transmission? or will I have to get the slip fit ones and install them past the transmisson?cause I plan on running true dual exhaust.
Old Sep 16, 2002 | 06:42 AM
BamaZ28's Avatar
Talking
You should be able to. I had a friend with a late 70's camaro, he bolted glasspacks directly to the headers, and he had no problems. Just make sure and get some sort of turn downs so you don't burn the bottom of the car! It sounds bad a$$!!!
Old Sep 16, 2002 | 11:57 PM
TJS69's Avatar
Cool
You better make sure your transmission crossmember is for dual exhaust, or you may have to change it, Unless of ourse you feel the pipes will clear.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
