what is my problem
Old Sep 27, 2003 | 12:38 AM
Fred Jeter's Avatar
Unhappy what is my problem
I have installed 3.73 gears for 3.23 and i did not pick up any ET, MPH, nor better 60 ft time. Will the computer counter the new gear change but correct the odometer?
Old Sep 27, 2003 | 10:02 AM
This belongs on LT1 Tech, or Drag Racing.
what sort of traction did you have? What tires? Did you alter shift points? Did you correct your ET and MPH to standard conditions to compensate for any differences in temperature, barometer or humidity?
The computer can not change anything by itself. If you didn't change the gear ratio setting in the PCM, it may have affected shift points. And your speedo and odometer will be incorrect by 15%. If you changed the gear ratio setting in the PCM the speedo and odometer will be correct, but you might still have to tweak shift points.
What is the redline and trap speed?
Moving to "Drag Racing"......
Old Sep 27, 2003 | 12:39 PM
GUMP's Avatar
Earlier this year, I changed my gear from a 5.38 to a 4.88. The week before I ran a 6.91 (1/8th) at 98 mph with a 1.41 sixty foot time. After the change it ran exactly the same numbers sixty, 330, 1/8th, and mph!! Weather conditions were almost identical also. I do believe that my quarter mile times would have been quite a bit slower with the 5.38 though.
Best Regards,
Daren
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
