Slave Cylinder, Street twin Master Cylinder
Old Sep 24, 2003 | 09:27 AM
xxsaint69x's Avatar
Well, i finally ordered the street twin.
I was wondering if there is anyway i can test my Slave cylinder to make sure its still working like it should.
Also where can i get JUST the Slave. Thanks
Also, how do i go about bleeding evertyhing after i put the Mcleod master cylinder.
Thanks
Marcin
Old Sep 24, 2003 | 10:15 AM
PatriotTA's Avatar
I don't think its possible to get just the slave. I'm pretty sure GM only sells the whole hydraulic assembly. Install University has a writeup on the McLeod master cylinder install HERE. Granted its for an LS1, but it has a procedure for bench bleeding which should be the same for both LS1s and LT1s. After bench bleeding, I assume you just bleed it on the car like your normally would. Let us know how the install goes.
Old Sep 24, 2003 | 10:55 AM
xxsaint69x's Avatar
it has to be possible as few people on the board got some...but non of em say where from!
Old Sep 24, 2003 | 10:57 AM
m0nk's Avatar
I got just the slave from a local parts store, I think it was around 70-80$ bucks? I saw no reason to buy the whole damn thing from GM since I got the awsome adjustable one with the kit.
Old Sep 24, 2003 | 11:19 AM
PatriotTA's Avatar
Maybe try Murray's or AutoZone. Just call em up on the phone...
Old Sep 24, 2003 | 02:35 PM
xxsaint69x's Avatar
is there a way to test the slave to make sure its working fine?
Rod Bender
May 16, 2015 02:16 PM
Ringmaster72
Mar 19, 2015 03:32 PM
BPS
9
Mar 5, 2015 10:51 PM
Ringmaster72
Feb 25, 2015 03:15 PM
