Solid pinion spacer?
Old Sep 17, 2003 | 04:19 PM
TAChad's Avatar
I'm getting ready to install some 4.10's in my stock rear. This install kit came with a solid pinion spacer...i have never used one of these before. I have only done a couple sets, but is this worth installing? does it take place of the crush washer? what should be the tightening torque? any other hints/tips? Does anyone have or know of any writeups on gear installs? thanks for any info
Chad
Old Sep 18, 2003 | 12:01 AM
AL SS590 M6's Avatar
Moderator
The solid spacer takes the place of the crush washer. And the set-up is the same only instead of crushing the washer 'till you get the required preload you change shims.
Old Sep 23, 2003 | 05:19 PM
Maldo's Avatar
Is it easyer to do it that way?
any pictures of someone who has done it using the the solid spacer?
Old Sep 23, 2003 | 11:47 PM
Moderator
I think it's about the same level of difficulty.
Not that I know of.
Old Sep 24, 2003 | 03:38 PM
thermwood1's Avatar
It's about the same as far install goes. But if you have to take the pinion gear back out, you have to use a new crush sleeve, whereas with the solid piece, it can be re-used.
From what i have read on this forum, a lot of people like the solid spacer better. It's believed that it doesn't allow for as much movement like the crush sleeve.
IndyZman
Oct 22, 2015 02:17 PM
95chwagon
Oct 16, 2015 12:24 PM
Daluchman1974
Sep 11, 2015 06:12 AM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
