Tranmission problems
Old Aug 15, 2002 | 02:25 AM
1FastIroc87's Avatar
Post Tranmission problems
Here is the problem I have a 700R4. If you leave it in just overdrive it does fine. But if you power shift it it will go from first to second but lets say you hold the car at 3500rpm and then just let off the gas the car looses rpms like it is in neutral, then you push on the gas agian and the car wont pull untill it gets back to 3500rpms. I have been told the it is the torque conveter. What do you think
Old Aug 15, 2002 | 05:14 AM
Pro Built Automatics's Avatar
If you were to put the lever in manual low and go up to 20 mph and let off the gas, would the car deaccelerate?, or just go into a false neutral?
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
