Who has best bang for the buck performance chip?
Old Jul 1, 2002 | 04:40 PM
SharpZ28's Avatar
Post Who has best bang for the buck performance chip?
I have a 92 Z28 with TPI350 and was wondering who has experienced the most 1/4 mile improvement with what chip? My car is now completely stock with exception of Holley air foil and K&N cone filter.Thanks for any replies.
Old Jul 1, 2002 | 06:43 PM
mjcent922's Avatar
Until you get more mods I would hold off on a chip.Try bumping the timing up to 10 to 13 degrees.AS you start to put more mods on like headers,cam,intake,exhaust,then I would look into getting an edwright custom chip matched pertect to your mods.Don't forget to get a good convert(2800stall) and a set of 373 gears.You will be singing to the sound of low 13's or even maybe high 12's.
Old Jul 1, 2002 | 08:08 PM
brodyscamaro's Avatar
play with the timing and fuel pressure. dont get a chip unless it is custom or you did it yourself
Old Jul 2, 2002 | 01:12 AM
91 Redd Sledd's Avatar
Thumbs up
I agree with what the guys above said about matching the chip to your mods. I have an Ed Wright stage 2 chip in my car and I am very pleased with the results. When you are ready to do it I would highly recomend them. Pricing is also very good.
James
91 Z-28 305 H.O. 210 RWHP
crane hi-6,holley reg,air foil,3:73 richmonds,Ed Wright stage 2 chip,msd wires,SLP headers,best e.t 14.4@99.02mph
Old Jul 2, 2002 | 09:55 AM
guitargod33's Avatar
quick question...a chip should probably be the last thing to do, because any significant new mods means you'd probably want to get a new chip burned, right?
91 305 drop top
Holley air cleaner
Flowmaster 80 Series
Bosch Platinum 4+ plugs
160* thermo
Cragar S/S wheels-just so I could negate any speed I may have gained
more coming soon
Old Jul 2, 2002 | 12:13 PM
SharpZ28's Avatar
Thanks for the replies. I have a 87 Grand National that I have running 11.50s @ 116 in 1/4. The tuned port 350 is a whole different animal. I need to get some baseline runs on the car and start from there.
Old Jul 2, 2002 | 12:33 PM
1989gta's Avatar
i know lots of the turbo guys are running speed desity systems rather than wasting your money on a chip. try pokeing around www.turbobuick.com Some of the guys in my area are using speed pros system, i plan to upgrade to that. You can tune your car for what ever you want to do 10psi boost 20psi race gas, daily driving and so forth. Where with a chip you would need multiple chips to do this. $$$$
Old Jul 2, 2002 | 03:11 PM
SharpZ28's Avatar
Thanks for the input.The speed pro system sounds interesting,I will check into it.My GN is currently waiting for a convertor.My factory trans took a dump.I recently purchased the 92 Z28 and would like to get it hauling a**!
Old Jul 2, 2002 | 03:41 PM
IROCKER's Avatar
Does Ed Wright have a website at all?
1987 Camaro IROC-Z
350 TPI (L98), HyperTech Airfoil, K&N Filters and modified airboxes, AC Delco RapidFires, Taylor SpiroPro 8mm wires, Energy Suspension polyurethane bushings for LCA and sway bars, KYB struts and shocks, BFG g-Force Z-rated tires, MAC STB, MAC SFCs, JET low temp stat, CarSound Hi-flow Cat, 3" Mandrel-bent pipes, Flowmaster muffler, 3" chrome tailpipes, Vette Servo, TransGo Shift Kit, Vette 2000 Stall, TruCool LPD tranny cooler, T-tops.
Dynoed: 202HP and 292lbs-ft
1/4 Mile: 14.7s @ 92MPH
2001 Sunfire GT
2.4L, 5-speed, K&N cone filter, interior and engine detailing, 200W Monsoon Sound System (8 speakers), Silver Metallic exterior with grey interior.
Web: http://www.angelfire.com/on3/whitelightening
Old Jul 2, 2002 | 03:50 PM
Lounge Lizard 6's Avatar
http://www.fastchip.com/
Mike
'90 IROC-Z, 5-speed, ZZ4, G1 Trick Flows Moderator SEThirdgen
Old Jul 3, 2002 | 01:25 AM
aklim's Avatar
I have one from www.fasterproms.com and am very pleased with the results and the great tech support for diagnosing some other issues I had at the time. They get a chip as close as possible based on your mods and them have you make runs with monitoring equipment and them burn the chip till they get it on the money. They are around $500 for the first chip but after that, if you do more serious mods and need a new chip, it is around $150
95z_28_camaro_4_Ivan
May 8, 2015 09:56 AM
REDNECKISBOSS
Apr 13, 2015 07:55 AM
kksi
Feb 16, 2015 06:49 PM
AW/whiteZ-28
Jul 25, 2002 04:09 PM
LT1runner
33
Jul 24, 2002 01:19 PM
