yet another LT1 miss at high rpm thread
i dunno, maybe someone will know. my friend has a '94 Caprice 9c1, LT1 equipped. under heavy, consistant load or high rpm, it hesitates. he changed the plug wires tonite, and though it isn't nearly as bad as it was before, it still hesitates up high in the rpm. think a coil could be a quick fix?
Re: yet another LT1 miss at high rpm thread
I had the same problem, but i went from running 87 to 93 octane, which made a big difference, and then changed my plugs and wires, which terminated the miss. good luck
Originally Posted by toby360
Identical problems - Coil swap fixed it.
Noticed arcing off the bad coil when it was dark (VERY little but you would see occasional flashes)
I just did that no more than three weeks ago. Runs like a champ now
-Joe
10-31-2016 11:09 AM
sleeperZ96BT
06-05-2005 09:33 PM
Camaro90RS
07-23-2002 07:57 AM
