struggling to accelerate...
I have a 1994 Z28 (see sig for mods) and had a problem with hesitation in all gears and RPMs. Checked fuel pressure and found it to be at 21 psi so i replaced the fuel pump. Now it definately is better but it still has a problem accelerating. I don't think its missing of hesitating (not nearly as bad as before the fuel pump replacement) just seems to be lacking power. Anyone have any suggestions?
Re: struggling to accelerate...
Mine had a similar problem at one time, I ran some injector cleaner through it and problem solved. And I don't mean the kind you dump in the gas tank, I'm talking about pressurized kind. Give it a shot, it couldn't hurt, it could only help...
Originally Posted by CamaroSS30thAnn
plugs/wires? are u runnig rich ?
UPDATE:
I scanned the car today and it is running rich on both banks. I guess the coil is my next part to replace and to do the ICM Mod. After that i have to go with the opti
I replaced the left side O2 and waited to do the right side cause it looked like a PITA when i scanned it (before replacing the fuel pump) the left bank read lean while the right bank was ok. I would think they should both be leaning out if there was half the fuel pressure in the fuel rail. Now the left bank is slightly lean while the right bank (the one that read ok before) is reading a heavy rich mixture so im going to replace that sensor since it is still the old one and update this post after
Funny story, i got under the car today to do the o2 swap and what did i find, cylinder 2s plug wire had came loose from the opti Boy i feel stupid but at least i found the problem i am happy about that. Hopefully this solves it but im not too optimistic about those prospects.
jasonduaine
03-07-2015 09:44 AM
