how do you change plugs with bbk shortys
Its been over a hour and only got 1 and 3 done 5 and 7 i cant get to and the other side holy hell i changed them when i had manifolds in 2 hrs and when i built the motor i did it before it went in
well its in the driveway till i get it done i want to kill gm for there no space is good policy
Re: how and the hell!!! do you change plugs with bbk shortys
OK take a second and calm down i first time i did it with my shorties i almost lit the car on fire. But recently i was able to do it with out even jacking the car up. If you already have the drivers side done the passager is easy if you ask me just calm down. What i did do was cut a spark plug socket in half so it is short but i needed that for plug 7
well i am on the computer now cause i dont want to put a fist through the windshield but i am thinking i will pull the motor mount and jack up the motor
ah, just cut yours. or grind it down. that along with a swivel head ratchet wrench works best. i use the half socket to pull every single one of my plugs. makes it so much easier. as for the passenger side, pull the starter out to get to plugs 6 and 8. i have never worked with shorties though, so my advice is somewhat limited.
passenger side done! still looks like i have to pull the motor mount tomroow i hate it everything is so hard on these cars i am gonna sell it and get a old boat with a v6
well i will but i bought these about 3 years ago when it was stock over the winter i am doing l/t with straight x pipe to 3 inch bullets and turndowns
when we did my buddy's I was dating this girl that was like 5ft tall and she was able to get her hand in their and turn it with a socket. So my suggestion is to find a midget or small armed person
Re: how do you change plugs with bbk shortys
did'nt need to used a bent wrench it came right out
car is now one mean m/f no more detination it shifts at 6,600 rpms and is looking for low 11's on the 24th
in case anyone ever needs help i will do this for the search engine
396 lt1 stroker high compression spark plugs autolight racing 473 works best as a baseline
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
