Header bolt fell out!
Old 07-17-2014, 04:22 PM
Greg88's Avatar
So one of my middle header bolts fell out and I drove the car for about 10-15km. I think it's a fiberglass gasket. I put the header bolt back in, and it still sounds like an exhaust leak. Did it maybe burn the gasket up while it was loose? Also number one Cyclinder header bolts were loose aswell.
Greg88 is offline
Old 07-17-2014, 06:50 PM
parkers Z28's Avatar
Re: Header bolt fell out!
I would replace the header bolts when you replace the gasket
parkers Z28 is offline
Old 07-17-2014, 07:40 PM
Greg88's Avatar
I already replaced the bolt and it's still ticking
Greg88 is offline
Old 07-18-2014, 12:04 AM
Chimera96's Avatar
you probably burnt the gasket. just replace it. You need to re-torque header bolts after a few heat cycles of initial install......and not a bad idea to check them periodically
Chimera96 is offline
Old 07-18-2014, 01:27 AM
97WS6SCharged's Avatar
If you put a bit of teflon tape around the threads they won't back out quite as easily.
97WS6SCharged is offline
Old 07-18-2014, 09:14 AM
Use good gaskets (Fel-Pro 1406) and good bolts (ARP) to minimize the problems. The stuff that comes with a set of headers is usually poor quality.
Injuneer is online now
Old 07-18-2014, 11:10 AM
Greg88's Avatar
Ok thanks guys!
Greg88 is offline
Old 07-19-2014, 07:59 AM
Greg88's Avatar
Ok I have pacesetter headers and afr heads. They have the mr gasket gaskets which the ports are round and they have the fel pro ones that are square. All 1 1/2". Which do I go with?
Greg88 is offline
Old 07-21-2014, 09:45 AM
RUDEDOG's Avatar
D-ports.http://www.summitracing.com/parts/fe...-size/5-7l-350
RUDEDOG is offline
Old 07-21-2014, 03:36 PM
The Mr. Gasket CopperSeal are also available in D-port #7154
Old 07-21-2014, 05:16 PM
bw_hunter's Avatar
I used a set of Stage 8 locking bolts and never had the problem again....
bw_hunter is offline
Old 07-25-2014, 09:31 PM
Greg88's Avatar
So my local auto parts store ordered me fel pro 1404 gaskets not the 1406, wil they still work?
Greg88 is offline
Old 07-26-2014, 01:35 AM
Fatdog2's Avatar
After market headers have to be tightened at least once a year.Got this from a a master mechanic.Hope this helps.
Fatdog2 is offline
Old 07-26-2014, 07:31 AM
bw_hunter's Avatar
1404 are the standard SBC port shape, the 1406 are the D shaped port shape that your engine has. They'll bolt up but I think there will be gasket material sticking into the port. Why not get the right ones?
Old 07-27-2014, 05:18 AM
Greg88's Avatar
Yea I took the 1404 ones back and got the right ones yesturday! Thanks guys
Greg88 is offline
RUENUF
03-13-2016 03:39 PM
94Z28LS1toLT1
04-07-2015 05:37 AM
maybe2fast
03-16-2015 09:45 AM
cyteone
02-07-2015 06:04 PM
SavageZ28
17
07-14-2002 11:04 PM
Quick Reply: Header bolt fell out!
