Hydro carbons too high.
Old 07-01-2016, 11:12 PM
gunner125's Avatar
Emissions issues with A 1994 Z28. We have installed a new cat, injectors, coil and tune up. Car fails hydro carbons. Its currently running an ATI pro charger. Any ideas before I put my thru a wall??
gunner125 is offline
Old 07-02-2016, 02:15 AM
Fatdog2's Avatar
Re: Hydro carbons too high.
Ignition Timing?Rings?Vacuum leaks?Might post a sig.Hope this helps.
Fatdog2 is offline
Old 07-02-2016, 09:28 AM
What are the pass/fail limits and actual measured for unburned HC, carbon monoxide (CO) and oxides of nitrogen (NOx)?
How does the fuel system add the extra fuel on boost?
Injuneer is offline
Old 07-02-2016, 01:49 PM
gunner125's Avatar
1.1 to pass. 1st test the car was 3.6. Then we tuned it again with new plugs and coil. It dropped to 1.7. Last test with 24lb Injectors and the stock ECU back in the car it went 1 5. It passed all other tests.
Old 07-02-2016, 02:31 PM
RUDEDOG's Avatar
You have to get the cat real hot right before the test!
RUDEDOG is offline
Chimera96's Avatar
did you have the pcm tuned for the mods you have?
stock cam?
Chimera96 is offline
Old 07-02-2016, 02:43 PM
I understand it passed CO and NOx, but sometimes you can tell from how close those are to the limit, what is causing the problem.
Injuneer is offline
Old 07-02-2016, 03:30 PM
gunner125's Avatar
It was well under for the CO2 and NOX. The car is driven 20 minutes on the highway to get the cat hot. The cat is new, stock cam. It had a ECU that was prepped by the previous owner. We installed the original ECU and stock injectors.
Old 07-02-2016, 05:26 PM
Low CO and NOx can point to raw fuel. Since you replaced the injectors, check the fuel pressure and for a leaking fuel pressure regulator.
Do you have an FMU, is this a 2-bar tune..... again, how do you add the extra fuel for boost?
Injuneer is offline
Old 07-02-2016, 07:14 PM
gunner125's Avatar
CO number 4.3829 limit is 15.000. NOX is 1.125 LIMIT IS 3.00.Fuel delivery is apart of the procharger. It is apart of the kit.
Old 07-02-2016, 08:05 PM
This sounds like it needs to be moved to the "Forced Induction" forum. They will have a better idea of what's included in the typical ProCharger kit.
Injuneer is offline
Old 07-02-2016, 10:34 PM
New post on Forced Induction.
https://www.camaroz28.com/forums/for...2/#post6987614
Injuneer is offline
95_lt1_z28
08-30-2015 06:17 PM
sherwinZ28
11
08-15-2015 05:38 PM
colts0455
07-04-2015 02:32 PM
Nellsw88
05-26-2015 05:55 AM
Aneurysm
09-09-2002 08:09 AM
Quick Reply: Hydro carbons too high.
