95z28
Re: 95z28
Scan it for codes. Hard to do on a 95, because of the unique combination of an OBD-1 PCM and an OBD-2 "style" 16-pin ALDL connector. If you have access to an OBD-1 scanner, you can jumper the 12-pin connector, as shown by Shoebox:
http://shbox.com/1/xraycable.jpg
Even better, download the free Scan9495 software, get a cable from Red Devil River or ALDLCables (or build your own).
https://www.camaroz28.com/forums/com...95-lt1-874306/
Extended cranking can be due to several reasons, and the code may show something like a faulty coolant temp sensor. Extended cranking can also be due to rapid loss of fuel pump prime pressure, and you need to check the pressure with a fuel pressure test gauge.
bond2
01-21-2016 09:26 PM
NewsBot
01-13-2016 07:00 PM
