2 parts iso-heet 1 part lucas = death
#16
Actually, Iso-Heet is isopropyl alcohol, not methanol. Isopropyl is less harmful than methanol in fuel systems.....
http://www.imperialinc.com/msds0055120.shtml
From the manufacturing website:
http://www.goldeagle.com/brands/heet/faq.aspx
HEET
Q: How does HEET work?
A: HEET contains special additives and methanol. When HEET is added to the gas tank, it sinks to the bottom and mixes with any water. Since both HEET and water are heavier than gasoline, they go to the bottom of the gas tank. HEET absorbs water and keeps it from freezing, and blocking the flow of gasoline through the gas line and fuel pump. When the vehicle is started, the additives, methanol, water, and gasoline are consumed during combustion inside the engine.
Q: How does Iso-HEET work?
A: Iso-HEET contains isopropanol and special additives including Fuel Injector Cleaner.
It has Isopropanol in it. But it's major constituent is METHANOL.
#17
turns out i had a coolant sensor go bad. the guy said it was reading -7 whatever that means and basically my engine was trying to use gas like it was cold all the time giving me about 8 miles to the gallon. anyway i dont really know why that happened at the exact time i added iso-heet
#18
No I'm sorry, it's methanol.
HEET
HEET
In any case, this isn't worth arguing about. I won't be adding anything further
