Still no radio am or fm
I posted before about this double checked everything even had a friend suggest a new radio.the connections and antenna are fine,it plays cd. .am fm radio is all static none of the speakers are blown it's the stock Bose and it always worked fine.im not into stereo systems or aftermarket radios.should I just take a chance and buy a stock one from hawks or somewhere else? Thanks again
Prominent Member
Location: Born on the Florida West Coast, now where can I retire?
Re: Still no radio am or fm
How do you know the antenna is fine? Try unplugging it at the radio and sticking a very small screwdriver gently into the center of the socket. Attach a 3 foot piece of wire to the screwdriver and see if it works.
I had the same problem.I opened the hatch with the radio on and in the spare tire area I have too much antenna wire but i wiggled it around and found a place where the reception was good and duct taped it to the inside of the fender wall temp.The wire was also wound in a coil and I unhooked the coiled wire and moved the wire till I got reception.Also look for corrosion in and about the wire to antenna area. I live in a hilly area of Los Angeles so reception works or fades.Hope this helps.(After market radio with too much antenna wire for the car here.My02.
OutlawPerforman
10-30-2017 05:40 PM
Bigfatrat
Parts Wanted
10-16-2015 04:48 PM
