scanner comm prob
Old 02-09-2016, 11:44 AM
vicki711's Avatar
scanner comm prob
i have a 95 z28 6spd. had the engine and ecm redone last summer .got the car running and the fuel pump went out.put a new pump in fired it up and let it runabout 10 min then it started sputtering and backfiring throught the intake and set a service engine lite. my 95 has the obd1 system with the obd2 plug. i bought a scanner to do both 1 and 2. plug it in and it powers up but says unable to connect check dlc connection. all fuses are good nothing seems out of the ordinary any ideas what may be goig on
vicki711 is offline
Old 02-09-2016, 03:32 PM
Re: scanner comm prob
What brand is the scanner? Are you manually switching it to OBD-1 mode (serial data is on pin 9 on a 95 OBD-1, pin 2 on a true OBD-2). Do you have 12V at pin "16" (lower row, right hand corner)?
Injuneer is offline
Old 02-09-2016, 03:52 PM
vicki711's Avatar
i bought the innova 3120 from all the research i did it says it should work. i also callled their tech support numvber and the as well said it shoudl work..tried on a few other cars just to make sure it worked rite all went goood...
vicki711 is offline
Old 02-09-2016, 04:09 PM
Answer the rest of the questions.
Read post #2 in this thread:
https://www.camaroz28.com/forums/gen...rchase-882598/
Injuneer is offline
Old 02-09-2016, 06:57 PM
vicki711's Avatar
not really sure what u mean manually switching it over? i have a 16 pin connector on the car and on the scanner....
vicki711 is offline
Old 02-09-2016, 07:36 PM
vicki711's Avatar
i checked the voltage the bottom ritght pin. im showing 11.83 volts at the pin..
vicki711 is offline
Old 02-09-2016, 09:35 PM
How does the scanner know if it's reading an OBD-1 PCM or an OBD-2 PCM? It has to know which pin in a 16-pin connector feeds the data stream. Do you have to enter a VIN, engine code, etc.?
Injuneer is offline
Old 02-09-2016, 09:39 PM
The Innova 3120 is known to not work on our cars.
Innova 3120d OBD1/OBD2 scanner - review - ECM/PCM Product Reviews - Firebird Nation
shoebox is offline
Old 02-09-2016, 09:55 PM
I posted a link to a thread that indicates that. If he had done a search on "Innova 3120" he would have found that post, showing where it did connect, it would produce a faulty list of 8 codes, because as GaryDoug discovered, it has a faulty database for the codes.
Injuneer is offline
Old 02-10-2016, 05:49 AM
Prominent Member
GaryDoug's Avatar
Location: Born on the Florida West Coast, now where can I retire?
Your research has failed you. Return the Innova 3120, and for about half the money buy this one, which will work:
Amazon.com: Actron CP9185 Elite AutoScanner Diagnostic Code Scanner: Automotive Amazon.com: Actron CP9185 Elite AutoScanner Diagnostic Code Scanner: Automotive
You will need the CP9127 OBD1 cable adapter also:
GM OBD I ALDL Cable Kit Cp9127 - Actron (CP9127)
Amazon has the best price on the scanner but not on the adapter cable.
My review:
Actron CP9185 Elite AutoScanner - ECM/PCM Product Reviews - Firebird Nation
GaryDoug is offline
Old 02-10-2016, 11:17 AM
vicki711's Avatar
well thanks for the scanner info..sounds like even though they say it should work there are more people who telll me it dont...it dont help the scanner instructions have one paragraph oh how to use this pile of crap...another ? right before the car diedi went to hit the gas it sputtered bad smelled really rich and backfired through the manifold...sound like a bad ecm or iac or tps ? ideas
vicki711 is offline
Old 02-10-2016, 02:51 PM
Sounds like opti rotor failure.
shoebox is offline
Noenav
04-30-2015 01:06 PM
ad356
04-11-2015 10:30 PM
Sauced
03-29-2015 10:53 PM
F(ast)-body
02-26-2003 09:05 AM
danielbmx
08-27-2002 11:11 PM
Quick Reply: scanner comm prob
